Anyone run cooler T-stats in their LS?
Discussion in 'High Tech Retrofits' started by badazz81z28, Jun 14, 2019.
  1. badazz81z28
    16,173
    377
    Las Vegas, NV
    I will have mine apart...is it even worth the money and time to swap the 195 for a 180 or even 160?
  2. Goat
    1,891
    40
    Jun 7, 2001
    moncure, NC
    Why?
  3. ZEN357
    ZEN357 Veteran Member
    363
    63
    Feb 12, 2018
  4. Goat
    1,891
    40
    Jun 7, 2001
    moncure, NC
    Cooler is not necessarily 'better'...
    Don't have time to get into it right now, will check in later.
    Knuckle Dragger likes this.
  5. CorkyE
    10,111
    384
    Good question. :)
  6. G72Zed
    G72Zed Veteran Member
    909
    185
    Sep 8, 2015
    ^^ Correct, my old notes stated 20% increase cylinder wear going from the baseline of 170 to 160, sweet spot was 170-180.
  7. badazz81z28
    16,173
    377
    Las Vegas, NV
    Seems like something a lot of folks do for HP gains. I will have it off, so seeing if I should take advantage of the opportunity.
  8. CorkyE
    10,111
    384
    Cooler inlet air will gain horsepower more than lower coolant temperature. I'm fighting high inlet temps now that I've installed an Eddy Pro Flo 4 system, mainly because the old carb system didn't have an IAT sensor and I was just blindly unaware. I went with a 180* t-stat because the self learn feature doesn't kick in until coolant temp reaches 160*. I started watching the temps on my 05 Silverado with the 5.3 engine and it steadily stays around 200*. So I'm pretty confidant that GM knew what they were doing when they spec'd that thermostat. Modern engines (LS) with tighter clearances and thinner oils are designed to run at a higher temperature and changing that parameter can effect other components within the system. IMHO
  9. G72Zed
    909
    185
    Sep 8, 2015
    Correct, I guess it depends what your looking for, ultimate dyno run, 1/4 mile or best qualifying lap to make the cut. I've done the "icing" of the heads/intake with 100* water temps and heat the oil to 280* at the minimum level. My good friend who worked for TRD in CUP would literally circulate ICE cold water through the engine at the same time circulate the oil through a large burner from the dry sump to 320+* just before qualifying, it was crazy.
    If not, a 170-180 would be a good choice. Keep an eye on the oil temp if you go down in thermostat.
  10. G72Zed
    909
    185
    Sep 8, 2015
    x2 with CorkyE, there is a reason why you need the heat, got to get the oil up/over 212*.
