Anyone see the new T56 Magnum "F"
Discussion in 'High Tech Retrofits' started by 76z28, May 20, 2019.
  1. 76z28
    76z28 Veteran Member
    2,051
    51
    Jun 29, 2009
    bakersfield
    I am curious to see if anyone has heard of it.
    I am looking into it as it will put the shifter farther back--although it seems like SST doesn't want to help me with the order on this.
    It is supposed to be a direct bolt in for F body car--eg same shifter location and everything.
    When I asked SST about it, the response was "
    The shifter for it will be way farther back than what it needs to be. I doesn’t have a traditional mount like the Magnum. All it is. Is a magnum with an Old 4th gen tail."
    Now based on my research, that shifter location is ideal to come through the auto console, which is what I want.
    Any ideas on this?
  2. dave@ztech
    3,503
    717
    Mar 27, 2016
    NY
    76z28 likes this.
  3. 1980RS
    1980RS Veteran Member
    3,508
    636
    Jun 17, 2006
    MN
    All the T56's from 93 to 02 used the same tail end from GM. The GTO trans I used was the same just had to get rid of the crummy shifter they had and change the cup for the ball. The only one I had that was shorted was the CTS-V trans I had, same as the 5th 6th gen Camaros now
  4. 76z28
    2,051
    51
    Jun 29, 2009
    bakersfield
    I know, I want that shifter location of the 93 to 02 because it sits farther back to where I can successfully use the auto console.
    I am curious as to how the tail end is different(EG: i cant use a mechanical speedo?)
  5. 1980RS
    3,508
    636
    Jun 17, 2006
    MN
    I think the CTS-V tailhousing was further forward.
  6. 76z28
    2,051
    51
    Jun 29, 2009
    bakersfield
  7. dave@ztech
    3,503
    717
    Mar 27, 2016
    NY
    That is true, however, you might want to be sure that when looking at these transmissions , you compare apples to apples, and most of the places that have quoted me, ask about the console , to be sure they quote the right setup.
  8. 76z28
    2,051
    51
    Jun 29, 2009
    bakersfield
    I have stated I wanted to use an auto console, but they seem to be more into "correct" restorations.
    If I can use a stock t56 location with the same capacities as a magnum, that would be the best of both worlds I would think
  9. badazz81z28
    17,083
    543
    Las Vegas, NV
    95BE64F1-05AC-4D2F-8B4D-0C754A5FAD5A.jpeg I used a stock LS T56 from a 4th gen in one of my past 78s....the shifter was too far back. I even had to cut into the floor support brace for the shifter. I think I had issues with the reverse selonoid too.
    I run the Magnum with the shifter in the furthest back position. Honestly I think if you flipped it 180, it would be in the stock location. Much further forward then the f-body trans. I honestly think the F model would be for the 4th gen guys because of this.
    76z28 likes this.
  10. 76z28
    2,051
    51
    Jun 29, 2009
    bakersfield
    Thank you! This is the kind of feedback I was wanting. I'll stick with the standard magnum and get it ordered in June.
