Anyone see the new T56 Magnum "F"
Discussion in 'High Tech Retrofits' started by 76z28, May 20, 2019.
  1. badazz81z28
    17,428
    611
    Alabama
    Can you imagine if the shifter was FURTHER back? lol
  2. 76z28
    76z28 Veteran Member
    2,085
    57
    Jun 29, 2009
    bakersfield
    Ugh I keep seeing different pictures of both the magnum and the stock t56...
    If your picture is accurate(and mine lands in the same place) then I will definitely be good to go.
  3. badazz81z28
    17,428
    611
    Alabama
    The OEM T56 shifter is almost exactly lined up with the output shaft on the tail housing. As you can see on the Magnum it’s further towards.
  4. 76z28
    2,085
    57
    Jun 29, 2009
    bakersfield
    Do you have a picture of it finished?
    I'm looking at what shifter handle I want to go with and what it'll look like put together with seats and possible a console
  5. badazz81z28
    17,428
    611
    Alabama
    76z28 likes this.
  6. 76z28
    2,085
    57
    Jun 29, 2009
    bakersfield
    I may have to go with a different console... Interesting
  7. badazz81z28
    17,428
    611
    Alabama
    That’s with the shifter in the aft position, not flipped to move more forward.
  8. 76z28
    2,085
    57
    Jun 29, 2009
    bakersfield
    Yeah I think I'll need it a little farther back, but then it gets into the brace... I'll likely just buy another console or recarpet everything
  9. angelo
    angelo New Member
    19
    Feb 2, 2012
    Columbus, OH
    Is anyone using the Hooker t56 hump for the swap? They claim it will work with a factory center console. It covers the center cut for the shifter for a t56 magnum (does not work for a 98-2002 factory t56).
  10. badazz81z28
    17,428
    611
    Alabama
    I have one, didn’t use it. I wanted to install it and have it sit under the carpet w/no console.
