Anyone use Autoplumb 20AN radiator hose replacement?
Discussion in 'High Tech Retrofits' started by czizza, Mar 7, 2020.
  1. czizza
    czizza Veteran Member
    1,062
    80
    Jan 8, 2004
    N. Massapequa, NY, USA
    I have the typical flexible chrome hose but this is the 2nd time it leaked and then after putting new rubbers ends on it which I thought I had super tight ... took a drive and the top hose popped out of the water neck. The neck even had a bead on it.
    So I am thinking of this:
    https://autoplumb.com/pages/20an-cooling-system-conversion-parts
    Anyone have first hand knowledge of this? Any other options you can think of?
  2. $ Mike 70 Z-28
    $ Mike 70 Z-28 Veteran Member
    1,008
    26
    Nov 7, 2002
    New York, NY
    looks pretty slick
  3. badazz81z28
    17,395
    604
    Alabama
    Seems like more of a leak hazard. What’s the radiator neck to water pump relation? There’s got to be a correct hose
  4. czizza
    1,062
    80
    Jan 8, 2004
    Does this give you an idea?
  5. badazz81z28
    17,395
    604
    Alabama
    Are you against an OEM rubber hose? This AN conversion is a little pricey too
  6. czizza
    1,062
    80
    Jan 8, 2004
    On the lower hose yes, I had them pop off at the race track after a 7k run the suction over comes the hose then when you let off the suction stops and the rush of displacement pops the hose ... it is not 100% of the time but has happened to me 3 times.
    The top hose never had a blow off but leaks are killing me.
  7. G72Zed
    G72Zed Veteran Member
    1,362
    386
    Sep 8, 2015
    I have used the wide band clamps and have had no issues as of yet, typical chrome angled water neck and upper rad hose. I can send you some picks if you would like, LMK.
    For the bottom, I re-angled the rad outlet, double clamped and used the steel spring wired ribbed lower rad hose, does not implode at high sustained RPM's with the high GPM water pump. Leaks in that area on a road course can rear it's ugly head in a hurry.
    mrfleet12 and czizza like this.
  8. TCinthe6
    TCinthe6 Veteran Member
    130
    40
    Nov 5, 2017
    Toronto, Canada
    The AN stuff looks cool, but it's overkill (price and functionality).
    I used two 90 degree silicone elbows with some turbo hose clamps and an aluminum tube to join them. Was probably around $80 to 90 bucks for the upper hose setup and looks clean.
    Zstar likes this.
  9. czizza
    1,062
    80
    Jan 8, 2004
    Got pictures?
  10. TCinthe6
    130
    40
    Nov 5, 2017
    Toronto, Canada
    Quick pic, but you get the idea.
  11. czizza
    1,062
    80
    Jan 8, 2004
    That works! I will try that next.
