Archie's 1980 Z28
Discussion in 'Project Progress' started by blaze4303, Nov 23, 2011.
  1. blaze4303
    blaze4303 Veteran Member
    113
    Jul 16, 2011
    blackwood, nj
    Archie's Cars and Concepts T-Top Z28
    Picked up this project In August 2011. It cost me more to tow the car then it did for the car. The Z28 is a complete mess. Battery shot. Got car running on pick-up but engine had bad rod knock. Plan is to paint #44 medium green on black interior.
    One of the things I First noticed was these odd cars and concepts t-tops.
    I Dove right in. First I pulled the interior. It had what appeared to be Monte Carlo seats. The floors seamed to be what I expected. I started with researched where to get floor boards. Could not find toe boards and seat panels included.
    2 bolt 350. Next I Jacked Up the engine, dropped the exhaust and the oil pan. Was hoping to be able to save the engine. It looked like a fresh rebuild. When I got to the lower end the oil pick-up was laying in the bottom of the pan. Spun Front bearing.
    September 2011. Pressure washed about an inch of undercoat off. Worked out well but very messy. Pulled off front end and then pulled motor. dropped fuel tank.
    Next up. Pull fuel and brake lines. Time to start cooking off the rest of the undercoating with a torch. By the way not much fuel to drain off the fuel tank. Sending unit shot. Tank reading half but was empty. There also was a rust hole in top of fuel tank, by the filler neck.
    November 2011. Almost All the undercoat is finaly off. Burning it off worked best. Gives you a hell of a headache.
  2. GOLF72
    GOLF72 Veteran Member
    2,186
    Jan 11, 2010
    CORONA, CA
    Welcome to Nasty...
    Fbody Warehouse can supply you with everything you need.
    I dig those flames. LOL
    Happy Turkey Day :)
  3. hoov81
    hoov81 Veteran Member Lifetime Gold Member
    811
    20
    Oct 31, 2010
    kenosha, WI
    Welcome. Looks like a fairly solid car. Good luck with your build
  4. ctchap70
    ctchap70 Veteran Member Lifetime Gold Member
    1,469
    Apr 29, 2002
    Fort Necessity, Louisiana
    Welcome aboard. Looks like a good start. Charlton
  5. duaneorr333
    duaneorr333 Member
    99
    Mar 13, 2009
    Yreka CA
    Nice project. Are you going to keep it stock (except the color)?
  6. Skaal-tel 79
    Skaal-tel 79 Veteran Member Gold Member
    3,417
    Jun 20, 2004
    CFB Petawawa, Ontario
    Looks like this was an INTENSE redneckmobile.
    Good luck fixin it up!
  7. EZFrank
    EZFrank Veteran Member
    133
    May 5, 2005
    Buffalo NY
    Looks like a solid start good luck
  8. jmykel86
    jmykel86 Veteran Member
    264
    Oct 31, 2007
    JBER AK
  9. Skaal-tel 79
    3,417
    Jun 20, 2004
    Careful, there could be mullets lurking anywhere inside that car. Next thing you know you'll be drinking pabst blue ribbon and highlighting on COPS. ;D nbl
  10. Blu-By-U 79Z
    Blu-By-U 79Z Veteran Member Lifetime Gold Member
    5,554
    18
    Feb 11, 2009
    Kentucky
    Nice project. Looks to be in decent shape. Code 44 green will look SWEET :cool:
