Automatic brake pedal install in a M/T car
Discussion in '1970 - 1973 Specific' started by TrplNckl1970, Oct 2, 2014.
  1. TrplNckl1970
    TrplNckl1970 New Member
    Dec 10, 2008
    Richmond, VA
    If you don't mind hotrod, let me know if you can find it and we can work out payment and shipping. That would be a huge help. There are a few assemblies on ebay from 80 and 81 MY cars for sale but I'm not sure if they are the same. Thanks for y'all's help
  2. bigdav160
    bigdav160 Veteran Member
    592
    Jan 11, 2006
    Klein Texas
    I have the auto pedal and box out of my '73. I don't want to part with it yet but I could take a picture if it would be helpful
  3. TrplNckl1970
    Dec 10, 2008
    Richmond, VA
    After looking at some pictures of different set-ups, I've determined that the pedal that I bought is for a first gen. It's now scrap metal...
    I do need the correct pedal though if anyone has one. I have the factory manual brake and clutch pedals if anyone wants to trade!
  4. KansasTwister
    KansasTwister Veteran Member Lifetime Gold Member
    1,389
    Oct 7, 2006
    Lawrence, ks
    There are three different brake pedal rod locations other than manual vs auto car, for a total of six id assume. The manual and power brake pedals share the same drilled holes, but the pivot rod goes in a different hole. The power 4 wheel disc cars use a rod location slightly different than the other two, but IIRC the upper hole stays the same. You may be able to swap the rod from upper to lower position if needed but I never tried. We collected alot of different pedals when I went to set my car up for a stickshift so we looked at the differences through the years.
  5. KansasTwister
    1,389
    Oct 7, 2006
    Lawrence, ks
    But auto brake pedal should go right in no issues. My brake pedal is from a 76 ta and my clutch from a 72 camaro.
