Backfiring and no power
Discussion in 'Troubleshooting & Diagnosis' started by WiggyB31, Sep 26, 2019.
  1. dave@ztech
    3,478
    714
    Mar 27, 2016
    NY
    I hope fuel wash didn't ruin that engine at break in. You seem to be on the right track now, good luck!!
    hubedobeedo likes this.
  2. flht99b
    flht99b Veteran Member
    269
    44
    Nov 28, 2014
    Knoxville, TN
    I assume the cam in your engine is a flat tappet hydraulic. Popping from the carb indicates an intake issue. You could have an intake valve adjusted to tight. I no longer adjust hydraulics with engine running, instead do each cylinder at TDC on compression, adjusting them to 0 lash and then add the 1/2 turn of preload per cam manufacturer.
  3. xten
    xten Veteran Member
    2,948
    1,720
    Sep 24, 2014
    Pittsburgh, Pa.
    Do you have the stamped steel rockers? The adjusting nuts wear over time and need replaced or they won't stay put and will loosen on their own. If you have roller rockers I would highly recommend poly locks. But it does sound like an intake valve problem (too tight, bent, burnt) or an intake lobe on the camshaft.
  4. budro6968
    budro6968 Veteran Member
    3,275
    525
    Apr 2, 2016
    Jax Florida
    My 2 cents. Redo the Dizzy set up. If you have it wired to run at 180 out, sure you can get it to run. The thing is trying to set timing will probably be an issue B/C the Vac advance can will hit the engine or Fire wall depending on which way you need to go to get timing set.
  5. Twisted_Metal
    27,071
    1,004
    ^+1
    I don't know why any paid mechanic would reroute all of the spark plug wires when it takes far less effort to restab the distributor to do it the "right" way.
  6. flht99b
    269
    44
    Nov 28, 2014
    Knoxville, TN
    Agreed. But I cannot tell you how many "pro built hot rods" as well as daily drivers that have the distributor incorrectly installed and the spark plug wires moved to make it work.
  7. WiggyB31
    WiggyB31 Member
    54
    14
    Jun 21, 2019
    20191001_200302.jpg 20191001_200322.jpg So I got one of the heads off last night (had to work late) and I must say I've see better heads on an older engine. To say there's less than 10 hours of run time on this supposed to have been fresh rebuild there's a lot of carbon on them.
  8. flht99b
    269
    44
    Nov 28, 2014
    Knoxville, TN
    Looks like it was running very rich.
    WiggyB31 likes this.
  9. WiggyB31
    WiggyB31 Member
    54
    14
    Jun 21, 2019
    I would say yes it was when it had the dual carb setup on it (like that when I got it) so damage had been done clean them up and start new.
  10. WiggyB31
    WiggyB31 Member
    54
    14
    Jun 21, 2019
    20191002_183816.jpg 20191002_183831.jpg Ok got the other side off and it's not as bad. Off to the shop tomorrow and see what comes back. May be over kill but I want to make sure it's right. If the check out ok I'm going to pull the cam and fix that 180 out crap too.
