Backfiring and no power
Discussion in 'Troubleshooting & Diagnosis' started by WiggyB31, Sep 26, 2019.
  1. cadillac_al
    cadillac_al Veteran Member
    842
    87
    Apr 22, 2015
    Maine
    All this timing and valve adjustment confusion is mind boggling. This used to be basic stuff that any high school drop out could understand. I can't tell if those are flat top pistons or not. I would check the deck height and if it isn't 0 decked I would ditch the thick head gasket and run shim gaskets like the factory did. If it is 0 decked then those Fel Pro gaskets would be perfect.
    Maybe the cam installation should be double checked so might as well see what's under the timing cover. If the dots line up it should be close enough to run fine. Degreeing the cam is the preferred way if you have the time, especially if the cam is unknown. If the cam is unknown I would seriously consider doing some cam shopping. Then adjust the valves, drop the dist in correctly and enjoy.
    hubedobeedo and WiggyB31 like this.
  2. roeville
    roeville Veteran Member
    1,247
    87
    Oct 9, 2000
    SF East Bay CA
    When you pull the cam, take a good look at the cam lobes.
    hubedobeedo likes this.
  3. WiggyB31
    WiggyB31 Member
    54
    14
    Jun 21, 2019
  4. cadillac_al
    842
    87
    Apr 22, 2015
    Maine
    Well that's a new one for me. I have heard lots of lifter ticks and carb popping but I have never heard that kind of popping. That's coming out the carb? It definitely sounds like a mechanical/metallic metal on metal tapping slower than the rpm's. It must be a cam or valvetrain problem. BUMMER! I'll have a drink for you.
  5. cadillac_al
    842
    87
    Apr 22, 2015
    Maine
    I really hate to question another man's valve adjustment but I think a severely mis-adjusted valve train could cause your issues too. I'm hoping that metalic sound isn't a valve kissing a piston. So you got your heads back, everything was ok so that is a plus, have you installed them yet?
  6. WiggyB31
    WiggyB31 Member
    54
    14
    Jun 21, 2019
    Well I haven't reinstalled the heads yet im going to change ot the cam since im already there. My dad has a general kenitics cam he got a while back and it's just been sitting in the closet. Once I get it all back together I'll update the thread. Should be early next week since I have to drive to VA this weekend and get the cam.
  7. WiggyB31
    WiggyB31 Member
    54
    14
    Jun 21, 2019
    That's what I paid the performance shop to do. Lesson learned so I'll do it myself this time.
  8. cadillac_al
    842
    87
    Apr 22, 2015
    Maine
    I just saw this video recently. It makes perfect sense to me and is a lot simpler than the IOEC method that I have used all my life.
  9. WiggyB31
    WiggyB31 Member
    54
    14
    Jun 21, 2019
    This idea a very good video and my lifters should be in today. First thing I was going to do was soak them like my dad taught me. Not any more I'll let you know how it goes. Thanks for the heads up.
  10. WiggyB31
    WiggyB31 Member
    54
    14
    Jun 21, 2019
    20191013_201112.jpg 20191013_201104.jpg 20191013_193955.jpg So got the water pump and cover off today. Remember how I was saying the timing was 180 out. Well the pics attached will explain why. Notice #1 is up TDC.
