Backfiring and no power
Discussion in 'Troubleshooting & Diagnosis' started by WiggyB31, Sep 26, 2019.
  1. Vettenick
    Vettenick Vettenick
    104
    19
    Jul 17, 2019
    Sorry, maybe my eyesight is not that great. If the crankshaft is at TDC for #1, then why is your cam gear mark at 10 o'clock?
    The mark should be at 12. Do you agree? Also, is that a multi-keyed crank sprocket? If so, is that positioned correctly? Just curious, what positions are your rocker arms in for #1?
    WiggyB31 likes this.
  2. WiggyB31
    WiggyB31 Member
    54
    14
    Jun 21, 2019
    That was my problem the entire time everything is off. So im not sure if a lobe is written on the cam or not I'm changing it anyway. Better to be Dave than sorry.
  3. Vettenick
    Vettenick Vettenick
    104
    19
    Jul 17, 2019
    You should talk to the engine builder to see if they'll reimburse you? And...I'd never go to them again.
  4. WiggyB31
    WiggyB31 Member
    54
    14
    Jun 21, 2019
    Well I brought the car where the guy said he had just rebuilt it. Then took it to a performance shop so they could double check everything. That's where money was wasted since I have to check them.
  5. Vettenick
    Vettenick Vettenick
    104
    19
    Jul 17, 2019
    Sorry you had such a bad experience. They should run these guys out of the business. Good luck!
  6. WiggyB31
    WiggyB31 Member
    54
    14
    Jun 21, 2019
    Thanks but it's cool...... like they say you want something done right you have to do it yourself.
  7. WiggyB31
    WiggyB31 Member
    54
    14
    Jun 21, 2019
    So took out the cam and lifters today. Not good glad I just said f#@k it and decided to replace them.
  8. Twisted_Metal
    27,087
    1,011
    Wow... That’s a steaming pile! :eek:
    There’s going to be a lot of glitter hiding in every oil passage in that block.
    It’s going to take some serious cleaning to even consider using it for another rebuild.
    You may want to consider a crate engine (or short block) at this point.
  9. rocket dawg
    rocket dawg Veteran Member
    334
    28
    May 5, 2015
    Grand Rapids Mi
    That is junk. Like mentioned above, it needs to be torn down completely and start over or toss it in the scrap pile and a new short block at minimum. I would not re-use any of the parts including the push rods or the oil pump. In the video it almost sounds like the oil pump inst working. Saw it once years ago on a dodge 318 where the distributor shaft wasn't long enough to engage the oil pump.( this was on a new crate engine--rebuilt actually) the cam turned the dizzy but not the oil pump, why dodge made 318's with different shaft lengths baffles me,but anyway...) It made that exact sound in your video as far as I can tell. We pulled the valve covers and noticed zero oil at the rockers and shut it down. Even your cylinder heads now need a bath. maybe a good running used engine is in order.
  10. Vettenick
    Vettenick Vettenick
    104
    19
    Jul 17, 2019
    So, other than the engine being out of time, what caused the cam to wipe out? Was it a loss of oil pressure. If so, then no doubt the motor is done. I would definitely make those guys pay up. This is going to cost serious money.
