Backfiring when let off gas
Discussion in 'Troubleshooting & Diagnosis' started by Newtoy78z, Sep 29, 2019.
  1. Newtoy78z
    Newtoy78z New Member
    Sep 29, 2019
    Just purchased a 78 Z28. I had the original exhaust manifolds replaced with headers and replaced both mufflers. She doesn’t miss a beat when idling just backfires when you let off the gas. Sounds like coming from driver side. Also sometimes she starts on 1st try other times takes a couples of tries. Any suggestions? Thanks
  2. bourbon_scotch
    2,357
    123
    Jan 10, 2003
    USA
    change the timing
  3. tom3
    tom3 Veteran Member
    11,921
    327
    Aug 1, 1999
    ohio
    Sometimes an exhaust leak will cause the backfire too.
  4. mallard
    mallard Veteran Member
    505
    99
    Oct 3, 2013
    SK, Canada
    Backfire or a "rapping" sound? A loose muffler baffle can mimic that sound as well.
  5. ZEN357
    ZEN357 Veteran Member
    383
    70
    Feb 12, 2018
    Correct Spark Plugs?
  6. cadillac_al
    cadillac_al Veteran Member
    832
    85
    Apr 22, 2015
    Maine
    Backfire like a rifle shot or minor lean popping?
  7. larrylarry
    larrylarry Veteran Member
    1,544
    70
    Dec 22, 2011
    San Antonio Tx
    Exhaust leak. Air is getting inside the pipe also could be a timing issue to.
  8. Vettenick
    Vettenick Vettenick
    59
    12
    Jul 17, 2019
    Other than the headers, is this car stock with any emission equipment still installed, like EGR ? Did you have this problem before the headers, or did it start right after the headers?
