Barrier between tank and exhaust?
Discussion in 'Tips 'n' Tricks Topic' started by badazz81z28, Apr 13, 2019.
  1. badazz81z28
    16,923
    502
    Las Vegas, NV
    So I my luck was 98% there with my custom fuel tank. The exhaust rubs on the corner of the tank. I would like to put something to sit between them. Thinking felt....but what you all think?
  2. tom3
    tom3 Veteran Member
    12,008
    342
    Aug 1, 1999
    ohio
    I would really try to move one or the other. Something should give.
  3. badazz81z28
    16,923
    502
    Las Vegas, NV
    They don’t, vibration brings them back together
  4. dave@ztech
    3,478
    714
    Mar 27, 2016
    NY
    I would think a plate to keep them seperate and to not allow them to rub together, if it rattles, then put rubber on the plate both sides if need be
  5. hubedobeedo
    hubedobeedo 3rd times a charm
    491
    157
    Jul 18, 2013
    Huntertown,IN
    you probably should get a thermal barrier type material to wrap exhaust if anything i would try to add clearance to the immediate area on the exhaust pipe(dimpling) . jegs has some products that might be helpful. definitely do not want them touching .
  6. Jim Streib
    371
    44
    Apr 6, 2004
    Saint Louis, MO USA
    I would take the exhaust pipe out, bend it to gain the needed clearance, then reinstall it.
    Jim
    RS1979, Dave Nelson and mrfleet12 like this.
  7. DB Z28
    DB Z28 Veteran Member
    564
    42
    Nov 30, 2003
    Fond Du Lac
    I would clearance the pipe a small ding with a hammer just a little. I could not stand a pipe rubbing on something or tack weld the pipe so it can,t move
    mrfleet12 likes this.
  8. dcozzi
    dcozzi Veteran Member
    3,092
    421
    May 1, 2002
    Phoenix, AZ
    Or ding in the tank. It will be the easiest with a 3lb sledge and folded hand towel over the tank while you "massage" it. Or does it rub on the crimped part?
    Sorry, just re-read. CUSTOM FUEL TANK. Take a hammer to the exhaust pipe.
  9. Bandit723
    Bandit723 Veteran Member
    3,148
    464
    Oct 1, 2016
    Waupaca WI
    BFH
  10. Revin
    Revin Veteran Member
    549
    91
    Aug 31, 2016
    Round Rock , TEXAS
    Remove tank and put nice one inside trunk! (I know you want to):D
    Oh and give the old one to me!:)
