Barrier between tank and exhaust?
Discussion in 'Tips 'n' Tricks Topic' started by badazz81z28, Apr 13, 2019.
  1. CorkyE
    10,272
    430
    Universal but correct in most applications answer. My right side pipe is really close, I put some high temp header wrap around the exhaust pipe.
    hubedobeedo likes this.
  2. Dichard
    Dichard Veteran Member
    147
    100
    Jul 5, 2018
    Mesa, Arizona
    I would go with hubedobeedo, THERMAL BARRIER TAPE, or Exhaust Wrap or both, but in the same instance you might have to dimple the exhaust pipe. This is one of the main reasons I am going with turn downs right after the axle, there is simply NO Clearance for the tail pipes.. Anyway ——-> thermal barrier tape OR exhaust wrap!!
  3. Bandit723
    Bandit723 Veteran Member
    3,148
    462
    Oct 1, 2016
    Waupaca WI
    I just reworked some old pipes I have because of the same clearance issues by the gas tank. Same 3 inch tubing but just bent better.
  4. Zspoiler
    Zspoiler Veteran Member
    3,212
    252
    May 6, 2012
    Federal Way, Washington
    Can you get a picture if possible ? I would rather modify the gas tank than the exhaust for clearance .It all depend on just how much room you have, I use a sump stock gas tank and my stock from muffler to tip exhaust pipe on mine. So clearance isnt an issue.
  5. Bandit723
    3,148
    462
    Oct 1, 2016
    Waupaca WI
  6. Dichard
    147
    100
    Jul 5, 2018
    Mesa, Arizona
    Just looked over their website, there here in Scottsdale AZ, interesting for a couple reasons, 1. They are mostly Pontiac oriented, but they do cater to some Chevy stuff.
    Download the catalog, they have a lot of go fast stuff.
  7. Scott Sievers
    Scott Sievers Veteran Member
    209
    95
    May 22, 2018
    SE Iowa
    Rubber or thermal wrap will rub through in time. I have to agree with Jim. Fix the pipe. As much of a pain as it is, take it out and have someone massage it so it fits better. AS LONG as it doesn't RUB, THEN put the wrap on it.
