base over cured SPI epoxy
Discussion in 'Body Restoration' started by TX79Z28, Jul 1, 2013.
  1. TX79Z28
    TX79Z28 Veteran Member Lifetime Gold Member
    1,136
    May 3, 2007
    San Antonio, TX
    I have read many threads, as well as visited the SPI website and forum, and I am getting somewhat conflicting messages.
    I have the car in SPI epoxy (black) and plan on shooting slick sand, and 2K this week. Sometime before assembly, I want to shoot BC/CC over the "hidden" areas (cowl, tail light panel, etc). The epoxy will be WELL past the 7 day re-coat window. I have read of two methods:
    1. scuff cured epoxy with a red scuff pad, shoot thinned down epoxy (sealer) and then the BC/CC
    2. scuff cured epoxy as above, and shoot non-thinned coat of epoxy, BC/CC
    Which way is better? Is it just a matter of personal preference?
  2. spicewood1
    spicewood1 BANNED
    1,936
    Jul 16, 2001
    NC
    Why not lightly scuff the cured epoxy and go ahead with the color? That 7 day window is for topcoating without scuffing. After a week you HAVE to scuff. Call Barry.
  3. TX79Z28
    1,136
    May 3, 2007
    San Antonio, TX
    I have read of adhesion issues with just scuffing after its cured/after 7 day window. I guess just wanted to know if it was super important as to it was sprayed with full 1:1 epoxy, or a thinned out sealer version of it
  4. stevenp3762
    stevenp3762 BANNED
    1,466
    Feb 7, 2013
    bradenton fl.
    doesn't matter, it will just flow alittle better thinned.
  5. spicewood1
    spicewood1 BANNED
    1,936
    Jul 16, 2001
    NC
    Barry will answer all your questions. You will not have adhesion issues with scuffing - quite the opposite. I would not waste time and $ on more eooxy. Just scuff and shoot it w color
  6. allstar12316
    allstar12316 Veteran Member
    248
    Dec 6, 2011
    Manalapan, Nj
    You could either shoot straight color, or if you use another coat of epoxy I reccomend you thin it a little. This will help lay the over all job to lay down a little flatter and give more of a mirror like finish
  7. Rick WI
    Rick WI Veteran Member
    10,400
    Jul 9, 2001
    Madison, WI
    The nad thing about over reducing is the extra solvents. If the pressures at the gun are correct normal reduction with the activator will produce a very slick smooth finish.
    Solvents can get trapped under rop coat finishes and cause die back, or worse. A dulling affect. So need to allow extra flash time if you do that between coats.
  8. spicewood1
    spicewood1 BANNED
    1,936
    Jul 16, 2001
    NC
    I agree. I rarely reduce the epoxy . I am a believer that you want as little undercoats as possible for best long term finish. I have never once used a sealer.
  9. Rick WI
    10,400
    Jul 9, 2001
    Madison, WI
    Likewise. Unless I need a ground coat on a 3 stage I shoot directly over a prepped solid coat of cured 2k urethane primer.
  10. chevylet
    chevylet New Member
    10
    Mar 7, 2013
    Garage
    SPI says to scuff their epoxy if its out of the recoat window then shoot 1 coat reduced. Let sit over nite and follow with your primer. Shoot 2-3 coats urethane or polyester. let it cure for a day or overnite before starting to block.
