BBC engine mounts for 79
Discussion in 'Engine Topic' started by LoweRider, Mar 4, 2019.
  1. LoweRider
    LoweRider Member
    79
    14
    Jun 26, 2017
    TX, USA
    I am ready to pull the trigger on some engine mounts, but I need some confirmation I'm ordering the right parts before I go ahead.
    I am planning on using 2-1/8" headers on my BB, and the only info I can find is using Energy's 3.1114 mounts, swapping in 1971 frame mounts, or using the original mounts.
    Obviously I'd like to use poly mounts for the strength and longevity, so I'd like to know what parts everyone is using so I wont have any issues.
  2. BigBlock73
    2,022
    60
    Jul 10, 2002
    Accord,New York
    I used the clam shell poly mounts when I installed mine.
    turbobuick likes this.
  3. 1980RS
    1980RS Veteran Member
    3,202
    529
    Jun 17, 2006
    MN
    I run Moroso 62515 on the engine and 62630 on the frame, worked out great with big tube headers.
  4. LoweRider
    LoweRider Member
    79
    14
    Jun 26, 2017
    TX, USA
    How's the NVH with solid mounts?
  5. 1980RS
    3,202
    529
    Jun 17, 2006
    MN
    I guess I am drawing a blank on NVH? if you are referring to vibration that is not bad in the car.
  6. sevent3
    sevent3 New Member
    8
    May 30, 2011
    SANTA MARIA ,CA
    What brackets did you use on the engine ? Trying to put big block 454 in mine . Want to use clam shell frame mounts
  7. BigBlock73
    2,022
    60
    Jul 10, 2002
    Accord,New York
    I used the stock engine side mounts from my 73,307
    There are multiple holes in the frame for the clam shell mounts,I think this is because of the 6 cylinder engines that could come in them.
    Make sure your clam shell mounts are in the correct holes
  8. Da_Raabi
    Da_Raabi Veteran Member
    1,196
    184
    Jan 19, 2011
    Daytona Beach, FL
    I used OEM replacement frame-side mounts (about $5 each from anywhere) and the stock truck motor-side shells on my 454. It sits kinda high, but the hooker super comp headers fit good (had to trim a little off one motor-side mount) and it clears the giant truck oil pan. It also tucked those big super comps right up under the floor nice (lowered car, so clearance is an issue).
    My only issue is that I cannot fit anything but a bone stock iron intake on top with the stock air induction hood. Even so it still rubs. I'm trying to figure that one out now...
