BBc heads
Discussion in 'High Performance Modifications' started by 5spd540, Nov 7, 2009.
  1. 5spd540
    12,310
    Sep 19, 2009
    Guyton, GA
    What head can I get for my 454 to make about 600HP.
  2. 1971BB427
    1971BB427 Veteran Member
    748
    Sep 16, 2009
    Portland, Or.
    You can make 600 hp with stock oval port cast iron heads. You can put the best quality aluminum heads on and not get 600 hp.
    What I'm getting at is that 600HP wont be made with your heads, nor will it be restricted by your heads. The design of the BBC head is a very good design, and just port matching them to your intake manifold will work awfully well. With the right engine mods the stock heads will handle 600 hp.
  3. My73LT
    My73LT Veteran Member
    1,536
    May 29, 2001
    Orlando, Fla
    As long as those stock heads are not peanut port heads, and you can get some decent compression.
  4. 5spd540
    12,310
    Sep 19, 2009
    Guyton, GA
    How do I find out which heads I have.
  5. pdq67
    pdq67 BANNED
    10,496
    Jul 26, 2001
    Columbia, MO, USA
    post back the last three head casting numbers that are between the rocker studs.
    May be like a -215 or -063 or a -781 or -049??
    Or the PP head, the -236??
    pdq67
  6. LILRED496
    LILRED496 Veteran Member
    1,200
    Jul 14, 2008
    FLA
    Brodix RR BB-O
  7. LILRED496
    1,200
    Jul 14, 2008
    FLA
    Lets say you find a set for $100 get them decked,valvejob,checked for cracks,hot tanked,new springs.seals etc......
    Whats a port and polish job go for to get around 600hp ?
    When my dad did his 781s way back he had $900 into them and he did all the work himself.
    Id rather spend a little more and ditch the weight.
  8. pdq67
    pdq67 BANNED
    10,496
    Jul 26, 2001
    Columbia, MO, USA
    Fwiw, Mark Jones, (aka, Vortecpro), make's GREAT power w/ his reworked over stock heads so go from there!
    No more than just a bowl-blend and a good multi-angled seat job on say, an old closed chambered -206 head, .020" thick steel shim headgaskets on a stock '70's to '80's 454 P/U engine will wake it right up b/c the CR. will be up around 9.2 to 1 so that a decent 270 to 274 cam can be ran!
    pdq67
  9. theflash
    10,999
    8
    Feb 27, 2004
    Podunk, CT
    + 1
  10. jaywill
    jaywill Veteran Member
    1,048
    Sep 25, 2007
    REIDSVILLE,NC
    you can do it with these heads w/a little work ...i have the "215" on my motor they have a 5-angle valve job & port matched 2.19/1.88 valves..
    lilred is right if u have extra doe...
    i'm going to these heads...
    http://www.profilerperformance.com/bbc-heads-174.html
