BBC Hooker Super Comp header clearance?
Discussion in 'Engine Topic' started by alpinemetal, Mar 14, 2016.
  1. alpinemetal
    alpinemetal Member
    51
    Jul 5, 2014
    San Diego, CA
    Has anyone had any issues with clearance...the guy I got them from said I need to either modify my clamshells or use early 60's clamshells.
    Thanks
  2. mrdragster1970
    7,822
    507
    Apr 12, 2007
    I ran them and don't recall any issues. IIRC they were tight as heck, but they fit.
  3. Rust eater
    Rust eater Veteran Member
    133
    Feb 22, 2016
    Chicago Il
    If they are 2 1/8 primary tubes there will be tons of clearance issues. I have had to do some "custom" fitting on every big tube setup I have ever done.
  4. alpinemetal
    alpinemetal Member
    51
    Jul 5, 2014
    San Diego, CA
    Yes they are the 2 1/8 primary tubes where where your issues? Thanks
  5. mrdragster1970
    7,822
    507
    Apr 12, 2007
    I used them in the 80's, don't remember if I had to clearance the plugs or ??
    I know plenty of stuff claiming to fit suck, but they were made for our cars???
  6. alpinemetal
    alpinemetal Member
    51
    Jul 5, 2014
    San Diego, CA
    I was told I'd have to use early clamshells (I didn't know there was a difference) or take the plasma cutter to the ones I have. I dought there will be a problem with the bellcrank but has anyone had other clearance issues and if so where (im noth worried about the spark plugs).?
