bbc pistons L2308AF & 049 heads ??
Discussion in 'Engine Topic' started by mudhole, Dec 6, 2015.
  1. mudhole
    mudhole New Member
    14
    Mar 20, 2011
    BRISTOL,CT
    bbc 396 ??? 50cc dome pistons
    i have a BBC 396 with 50cc dome pistons # L2308af .585
    and want to use a set of 049 heads will this work ?
    the cam is a comp cams 11-250-3 574-578 flat taper
    comp 1.7 roller rockers
    air gap intake
    850 quick fuel carb
    any help thanks Rich
  2. 450bench
    450bench Veteran Member
    3,096
    31
    Feb 25, 2002
    memphis, tn-shelby
    2308 Pistons are for a 427, I think. 2287 is the big dome 396 piston. Regardless, I have run L2308 TRWs with an 049 head. Never an issue. I used cheap felpro rebuilder head gaskets, not that that matters.
  3. mudhole
    mudhole New Member
    14
    Mar 20, 2011
    BRISTOL,CT
    okay this is what i was told to do with the heads
    i put them on the block with NO head gasket put two bolts
    in to hold them on leave space so the head can lift up if the
    pistons hit the head this is on my stand i turned it over and it was
    good.i will be okay with high 12.+ compression ratio but do i need steel gasket
    for the heads ?? .041 head or .039 gaskets ?? and on my block there is only one water hole and the gaskets have 3 this is at the bottom of the block they are about the size of a dime can i drill them ??
  4. mudhole
    mudhole New Member
    14
    Mar 20, 2011
    BRISTOL,CT
    396 402-454 block ??? the numbers are 3969854 ceoa61819 date 1970
    pistons are l2308af
  5. 1980RS
    1980RS Veteran Member
    3,272
    548
    Jun 17, 2006
    MN
    As I remember form my TRW book, 2307 were 454 pistons and 2308 were for a 427. Both are open chambered pistons, but with 781 or 049 you need to do a little grinding on the exhaust side of the chamber to clear the domes.
  6. mudhole
    mudhole New Member
    14
    Mar 20, 2011
    BRISTOL,CT
    i put the haeds on the block with no gasket
    and two bolts left them lose and turned it
    over by hand on the stand the heads did not
    lift up at all so i think iam good ?
    the block # 3969854 comes up as 396-402-454
    # on front pad CEOA61819
    so iam thinking its a 402 with 427 pistons
  7. 450bench
    3,096
    31
    Feb 25, 2002
    memphis, tn-shelby
    Somebody had bored your block to 427 specs. Fair enough. I've seen it done before. You don't need steel shim head gaskets. Just run plain re-builder blue felpros.
  8. mudhole
    mudhole New Member
    14
    Mar 20, 2011
    BRISTOL,CT
    NOW i have a ? about the block there is only one hole for water at
    the bottom by the bolts its about the size of a dime the gaskets
    have 3 holes the heads also have the holes can i drill them out ??
    for the gaskets i was told to run felpro 1071 .041
    or felpro 1037 .039
    the 049 heads are 113cc
    pistons are 50cc
    so i will be around 12.1
    thanks for your help
  9. mech393
    mech393 Veteran Member
    843
    23
    Aug 9, 2003
    belvidere illinois usa
    I've taken clay and laid it over the top of the piston with the head bolted down on a used head gasket and with lifters and push rods installed and rotated slowly and then removed the head and cross cut the clay and measured I think you had to have 0.60 clearance I may be wrong on this its been along time but I could see how everything worked as a final assembly.
  10. mudhole
    mudhole New Member
    14
    Mar 20, 2011
    BRISTOL,CT
    ?? got that all set now what intake single plain or dual plain and witch brand
    want to run 850 carb
