Be prepared, C-Prepared Autocross (1981 Camaro)
Discussion in 'Project Progress' started by 1981paul, Sep 11, 2008.
  1. 1981paul
    1981paul Moderator Staff Member
    2,580
    85
    Jan 21, 2000
    Catonsville, Maryland MD USA
    Autocross only. There won't be much of any interior... Lexan and fiberglass everywhere possible, but technically I could put tags on it... Won't get far on a 5 gallon fuel cell and a 600hp motor.
  2. 1981paul
    2,580
    85
    Jan 21, 2000
    Rest of the cage came in, so I started on the front bars:
    Just have to notch and weld, then I can work on hanging the front coilovers and bodywork.
  3. BrianMassie
    BrianMassie Veteran Member
    162
    Oct 1, 2008
    Waynesboro, VA
    Want rear disc for your car? I have a Trans Am set from an 79 I decided to not use after I bought a disc brake rear complete.
    Brian
  4. Speed Happy '77
    Speed Happy '77 Veteran Member
    122
    Oct 15, 2008
    Olympia, WA
    5 gal. fuel tank and 600 hp? That's like running a marathon on just a power bar. Thinking out loud. So far, it looks very good.
  5. 1981paul
    2,580
    85
    Jan 21, 2000
    Car only has to run full bore for ~60 seconds, 3-5 times. I may consider a 10 gallon cell, but weight is key.
    Thanks for the offer on the brakes, but I'm doing a 9" rear, so I'll probably end up doing an Exploder setup.
  6. woody80z28
    5,570
    57
    Sep 8, 2004
    walton, ny usa
    Looks like this thing will be an animal.
  7. SR79
    SR79 Veteran Member
    422
    8
    Sep 14, 2005
    Carrollton/Sherman, TX
  8. 1981paul
    2,580
    85
    Jan 21, 2000
    Got a little more work done today, and at the end, it finally looked like a car.
    Dash bar in, engine bars welded in place.
  9. 1981paul
    2,580
    85
    Jan 21, 2000
    The broken and beaten glass front clip. I'll get to repairing it soon, but at least it was cheap.
    It's a car! Well, kinda. The front clip isn't bolted on, but it's something.
  10. SR79
    SR79 Veteran Member
    422
    8
    Sep 14, 2005
    Looks light, I like it a lot. Do you have a target final weight you're shooting for?
    I took my Scion to my first Autox yesterday, I'm definitely already hooked. I've been trying to decide what class our 79 will fall in.. I dug through the rulebook for a while, but I'm still not exactly sure.
