Bearing cup removal
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by 8pack, May 30, 2014.
  1. 8pack
    2,597
    146
    Aug 29, 2007
    Western, MA
    Bearing Race removal
    How the heck do you break the bearing cups free? I used a screw driver and a BFH and hit pretty darn hard and they didn't budge. Should I heat them up and then try again?
    Can I just put in new bearings and leave the old cups? The old cups are perfect, no scoring or sign of wear. Three of the old bearings are perfect but one got damaged when I stupidly dropped it.
  2. Protour-Camaro
    Protour-Camaro Veteran Member
    2,111
    Feb 16, 2012
    California
    Im guessing you are talking about the races? There should be a slot on the back side on the opposite end of the rotor. Hammer is out evenly, it should come right out. Are you trying to pry them out? (dont do that)
    I highly suggest using new races with new bearings.
  3. sevitz5
    sevitz5 Veteran Member
    1,618
    Feb 27, 2011
    Middle Point, Ohio
    Use a big socket and give them a good wack. I have heard that when you install the new race...put it in the freezer for a day before installing. It helps it go in.
  4. 8pack
    2,597
    146
    Aug 29, 2007
    Western, MA
    going to garage now....I didn't see slots in the back but will go check again.....will try the socket as well.
  5. 8pack
    2,597
    146
    Aug 29, 2007
    Western, MA
    Socket worked brilliantly on the small race. 1 1/8" Socket. Gave me a good idea of how hard you have to hit it...HARD.
    The big race I needed a Screw driver. Now way to get any other tool in there that I could figure out. I galled a small area on one rotor and had to smooth it out with the dremel. Took a lot of hammering to get them out.....but got them! New races are in the freezer right now.
    Thanks guys!
  6. Skip Fix
    Skip Fix Veteran Member
    2,170
    19
    Mar 21, 2007
    Katy,Texas
    Most guys use a large punch or brass drift to hit it with also, and sometimes the slots are barely there.
