Been out driving :)
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by gutted72, Oct 13, 2019.
  1. gutted72
    gutted72 Veteran Member
    1,320
    133
    Mar 4, 2002
    Jennings, OK
    So I've been out driving the Camaro a bit here and there and have a question :crazy:
    Does anyone else have problems keeping the backend under the car when going around corners? I understand if you are intentionally trying to, but this car will not take a regular corner, other than at idle.
    Don't get me wrong, I thinks it a blast. BUT, when the wife is in the car she doesn't really appreciate the spirited cornering. :eek:
    I would really have to think long and hard if I wanted to drive it in the rain. :brightide
  2. COPO
    17,682
    681
    Your not suppose to floor it so it squeals the tires just to impress people. A 4 cyl can do that too. Just drive it normal around a corner.
  3. gutted72
    1,320
    133
    Mar 4, 2002
    Jennings, OK
    I'm not even coming close to flooring it. I give it enough gas to get it moving, just like all my other vehicles and turn the wheel, a little more gas and then it slides the rear end.
    But on a side note, I'm still getting used to this Sniper EFI, so that may be part of it too :crazy:
  4. COPO
    17,682
    681
    Bald tires then or they are old and hard. I bought new tires this summer and they stick like I'm on rails around a corner.
  5. Green hornet
    Green hornet Veteran Member
    1,675
    278
    Oct 11, 2015
    North Bay, CA
    Sounds like 1%er problems. Lol. Tires could be an issue as stated above.
  6. BonzoHansen
    19,349
    724
    Jun 1, 2005
    Scott from Hamilton, NJ
    What size and type of tires are you running? What air pressures? What size sway bars? any suspension changes?
  7. 79T/Aman
    79T/Aman Veteran Member NastyZ28 Sponsor NazstyZ28 Sponsor Lifetime Gold Member
    2,480
    141
    Oct 7, 2004
    Dickson TN.
    as Bonzo said.
    But the Sniper has a sticky throttle issue as well, Holley has a "fix" for it
  8. Gary S
    22,409
    751
    This isn't a modern car with an on-off switch for a gas pedal. A carbureter is a progressive device that takes a smooth foot on the pedal to drive.
    A few years ago I had the displeasure of driving a Chevy pickup with a 5.3 and drive by wire. I could stop the truck, and then ease down on the gas pedal and the truck wouldn't move. I could get the pedal almost halfway to the floor and the computer still hadn't noticed it. The only way to make the truck move was to hammer the pedal to the floor so the computer noticed. It had only two positions, On and OFF.
    Try that with an old carbureted car and you would be 3 miles down the road cruising already.
  9. 8pack
    2,617
    148
    Aug 29, 2007
    Western, MA
    Sounds like you have some serious oversteer. Do you have a away bar in front and or rear? As asked before how old are the tires? Shocks? Suspension bushings new? If you have away bars, stock or adjustable.
    One if the suspension Gurus should be able to help out if you have all your data and facts. It is not the sniper...... you can add the progressive throttle linkage for cheap but I bet that's not it.... go to EFI System Pro if you need some help sitting out your sniper...
  10. John Wright
    14,663
    202
    Aug 9, 2002
    Rustburg, Va
    Old tires and too much rear sway bar and my car drove exactly like what you described. Normally they push like a dump truck, but this was on the verge of wrecking loose.
