Best build for a 400hp 350 on budget
Discussion in 'Engine Topic' started by Gregg, Mar 6, 2017.
  1. Gregg
    Gregg Member
    45
    Mar 3, 2017
    I have a Chevrolet 350 block 3970010 4 bolt main and I'm looking to get somewhere between 400 and 450hp out of it , what's the best options on a budget?
  2. GoldenOne7710
    4,794
    396
    Jun 23, 2004
    Athens, GA
    What's the budget?
  3. fatkid_racing
    fatkid_racing Veteran Member Lifetime Gold Member
    1,049
    90
    Sep 21, 2005
    Saginaw Texas
    Good short block prep with proper clearances (rod,main,rod side clearance piston gap etc). Vortec heads with a drop in spring kit or have the guides cut, .028" thick head gaskets and self aligning roller rockers.
    Retrofit hydro roller cam in the 220/230@.050 range 500ish lift, RPM airgap intake, 1-5/8" headers, 600-650cfm carb, good quality HEI with a decent curve 30-32 degrees total timing.
    Attached is a pic of the dyno results before tuning. 375 hp at the crank before carb tuning and ignition curve
  4. Edem_Alive
    Edem_Alive Veteran Member Lifetime Gold Member
    464
    9
    Dec 18, 2015
    Montana
    I put vortecs on a 360 but went with flat tappet instead of retrofit rollers. RPM airgap also. Hoping to be around 400 hp but it wasn't cheap. Would go the LS route if I did it again.
  5. djkaplan
    djkaplan Veteran Member
    162
    Mar 27, 2016
    Victoria, bc
  6. djkaplan
    162
    Mar 27, 2016
    Victoria, bc
    I take what I said back. buy a 5.3ls get the carbed intake and ignition box, cam and valve springs.
    youll have 6bolt mains and 450hp probably for less then 1000bucks.
  7. Rdobbs1977
    Rdobbs1977 Huge Guns N Roses Fan
    309
    15
    Dec 1, 2014
    Nashville
    ^^best response i've seen as of right now. Still not enough information though from Gregg. For starters what do you even know about the block? What if any parts do you have? What application are you shooting for?
  8. Gregg
    Gregg Member
    45
    Mar 3, 2017
    Just getting ideas of what I would need and a cost.
  9. Rdobbs1977
    309
    15
    Dec 1, 2014
    Nashville
    At the very least can you say one way or another if you have any parts whatsoever or just the block and nothing else? If you do have some parts, i'd be interested in what type of heads you have.
    Its hard for someone to tell you what you need when you've not really provided much information, come on!!
  10. larrylarry
    larrylarry Veteran Member
    1,544
    71
    Dec 22, 2011
    San Antonio Tx
    A 6 liter LS with headers is all that is needed for 400 hp
