Best heater bypass temporary solution ?
Discussion in 'The BS Topic' started by Z28PILOT, Apr 3, 2016.
  1. Z28PILOT
    Z28PILOT Veteran Member Lifetime Gold Member
    2,026
    17
    Oct 8, 2009
    Emerald Isle , NC
    My dang corvette heater coil is bad .:(
    So I want to make a temporary bypass I guess . Till I can get the parts I need.
    What is the best way to join the hoses ?
    It seems one is 3/4 " and one is 1/2" ...? Guessing
    Should I go to store and find pluming .? PVC or copper ? I'm not a plumer LOL
    Or is there some sort of pre made connector at an auto parts store for such fix?
  2. Mike N
    2,748
    523
    Jan 13, 2002
    Spencerport, NY.
    One should be 5/8" and the other 3/4", any parts store should have a plastic connector to join them together.
    Gates part number 28611
  3. Z28PILOT
    2,026
    17
    Oct 8, 2009
    Emerald Isle , NC
    Oh thanks ....very cool ! :)
  4. perkalator
    perkalator Veteran Member
    1,025
    89
    Aug 27, 2014
    kennewick wa
    You will not want to use standard pvc. It does not habe the proper temp rating. Use copper or iron fittings to make a temp bypass. Cpvc has a max temp rating for 200f. That is pushing it to close for me.
  5. dirtmod08
    1,953
    549
    Jan 17, 2007
    Central Illinois
    I just take the 5/8" hose and heat in up with a propane torch, it will stretch over the 3/4" fitting.
  6. sprink
    sprink Veteran Member
    500
    118
    Apr 27, 2008
    ffx, va
    Think I'd go brass. Plastic might get brittle w/ heat.
  7. Batman
    Batman Administrator Staff Member Lifetime Gold Member
    8,673
    Dec 13, 1999
    Mission Viejo, CA, USA
    Of course, you COULD always replace the heater core.....
  8. dirtmod08
    1,953
    549
    Jan 17, 2007
    Central Illinois
    Lmoa, nonsense.
  9. ol' grouch
    ol' grouch Veteran Member
    2,875
    783
    Jul 4, 2013
    Evansville, In.
    Who needs a heater in the summer?
  10. Twisted_Metal
    26,990
    966
    A short pieces of 5/8" copper tubing and a couple of hose clamps works well.
    That's what I did several years ago before I got around to replacing the core.
