ive used the brp motor mounts and their very pricey so I’m looking for alternative options that center the engine well and if possible please post pics of the mounts you have and are using Thanks By the way brp are 299
Not sure why anyone would pay more then this https://m.ebay.com/itm/LS1-Conversi...0bJZrDcm:sc:ShippingMethodExpress!89085!US!-1
Have you used them badazz? The ones I have centered it well and if I can find a less expensive alternative I’d take it but I also don’t want to be putting the engine with trans in and removing it more times than necessary over the mounts What did you use on yours ? How much where they ? And how did they center your block ? Pics ? Thanks
I used the steel version bought off of eBay. The ones I got were set-back. To get the LS to sit in the same position as a SBC, that’s what you will need.
Just a bit of a thread jack but thought while we are on the topic id ask. Does anyone make solid motor mounts for the ls in a second gen?
