Best O/D trans for my 71
Discussion in 'High Tech Retrofits' started by ffshu, Feb 28, 2012.
  1. ffshu
    ffshu Veteran Member
    254
    Mar 22, 2011
    New Kent Virginia
    I'm currently in the process of building a 71 and although I'm not at the stage of a trans, I'm trying to plan my attack. My plan is a street car with an appearance at the track every now and then. I'm shooting for 400-450 hp from my motor, so the million dollar question is, what is the best O/D for my car, and what do I need to hook it up?
    I don't know much about the difference btw a 700r4 and a 4L60 or 80 trans.
    All input and advise would be appreciated.
  2. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
    Read
    http://en.wikipedia.org/wiki/Turbo-....2F_4L60E_.2F_4L65E_.2F_Technical_Description
    The 700R4 is the 1980's version of the 90's 4L60 trans, and the 4L60e is the newest electronic version of it.
    A 700R4 used a Throttle Valve cable to get the proper pressures and shift points.
    A newer 4L60e uses a computer to do all that.
    The 4L80e is basically an updated computer controlled overdrive version of the TH400.
    The billy badass.
    I'm sure a beefed up 700R4 would do ya just fine if that's GROSS hp you're talking about.
  3. bandido
    bandido New Member
    16
    Jun 14, 2010
    Santa Maria, Ca
    i have a 700r4 stage two from bowtie overdrives.. it should be good enough for a healthy engine..
  4. Madmike72
    Madmike72 Veteran Member
    239
    Nov 26, 2010
    Walpole Massachusetts
    I put a built 2004r in my 71. Its the same size as the th350 I took out so the driveshaft is the same lenth. I've had a 700r4 and the gearing in the 2004r is better. 700r4 have a really steep 1st gear and a not steep enough 2nd gear. whatever you choose you're gonna love the overdrive when ya hit the highway. Its the best modification I've made.
  5. Brown`77Z28
    Brown`77Z28 Veteran Member Lifetime Gold Member
    1,326
    Dec 11, 2005
    The Netherlands
    +1 for the build 200-4R ;) ;)
  6. 70 gsconvt
    70 gsconvt Veteran Member
    1,101
    Sep 30, 2009
    Wadsworth, OH
    I have a 200-4R trans behind the 462 in my Buick. No problems. Go over to turbobuick.com. There is always one for sale over there.
    They do have to be built up to take the abuse of more horsepower. Expect to pay around $2-3K for a good unit.
  7. 70 gsconvt
    1,101
    Sep 30, 2009
    Wadsworth, OH
