big block swap 71 camaro
Discussion in 'Engine Topic' started by Jimmac, Nov 29, 2018.
  1. Jimmac
    Jimmac Veteran Member
    393
    71
    Dec 24, 2013
    tucson az
    havent done the swap yet so a few questions. 454 swapping out the 400,new 454 flexplate. do I need to ordered specific BB frame mounts? got a chevelle 4 qt pan, summit brand headers gtg?
    edlebrock rpm intake, how high out of the hood will the carb stick out? thx! jim
  2. Chevyforever
    Chevyforever Veteran Member
    668
    81
    Jan 4, 2011
    Mounts can be used as is, not able to comment about RPM intake.
  3. C4Racer
    C4Racer Veteran Member
    652
    118
    Oct 26, 2018
    4qt pan seems small. Is there a 6 qt available ?
  4. 1980RS
    1980RS Veteran Member
    3,523
    637
    Jun 17, 2006
    MN
    Yes, there are 6 and 7 qt. pans for big block Chevy's.
  5. C4Racer
    652
    118
    Oct 26, 2018
    I would run one of those if possible.
  6. Chevyforever
    668
    81
    Jan 4, 2011
    A full size oil filter must hold close to 1 qt.
  7. C4Racer
    652
    118
    Oct 26, 2018
    yes - good point
  8. Jimmac
    393
    71
    Dec 24, 2013
    tucson az
    it's a standard big block pan. std depth pan is considered a 4 at pan and add filter you get 5 qts. jim
  9. BigBlock73
    2,051
    61
    Jul 10, 2002
    Accord,New York
    Long tube headers from a Chevelle wont fit.
    RPM wont fit with flat hood
  10. Jimmac
    393
    71
    Dec 24, 2013
    tucson az
    I hope your wrong on the headers. the hedman headers I have says 1st gen camaro and chevelle. the summit brand headers lists the 2nd gen Camaro and chevelle I think it was g9010?
