Blower motor
Discussion in '1978 - 1981 Specific' started by Scott Cassidy, Dec 10, 2018.
  1. Scott Cassidy
    Scott Cassidy New Member
    Dec 7, 2018
    Hi,
    I am a new member. I own a 1979 Camero base model, that I have had for 17 years. The blower motor is on it's way out. Just wondering how to replace it. Do I need to take off the passenger inner fender or wheel well?
    Scott
  2. CorkyE
    10,265
    430
    Don't know about a non a/c car but it needs to come off if you have a/c. Just had my inner fender off a couple weeks ago to replace the heater core, tons of fun. I've heard of people cutting a large hole in the well, but I don't think you want to do that.
    BTW, welcome to NastyZ.
  3. Scott Cassidy
    Dec 7, 2018
    Ok thanks. The car does have AC.
  4. Twisted_Metal
    26,944
    925
    You don't have to completely remove the inner wheel well but you do need to remove all of the bolts up to where the lower fender extension attaches. Meaning... You don't have to mess with the battery or battery tray area. :D
    Once it's loose, pull the fender well down and hold it with a tarp strap or two.
    (Wheel off, car on jack stands.)
    You can make room that way to get your arm into the cavity where the blower motor hides. If you pull it down far enough, you can even get the motor/fan assembly out and the new one back in again!
    You may lose a little skin on your arms.
    I've changed blower motors two or three times this way over the years.
    Good luck
    gpm6367 likes this.
  5. Scott Cassidy
    Dec 7, 2018
    Thank you
  6. gpm6367
    908
    46
    Feb 12, 2005
    New Joisey
    So I don’t have to touch battery?
  7. Twisted_Metal
    26,944
    925
    I’ve never had to remove the battery to swap a blower motor.
    Once all of the fender well bolts are removed around the wheel opening, fender and frame, it will flex down far enough to gain access.
    Might be a little tight if you have “Popeye” arms. ;)
    gpm6367 likes this.
  8. gpm6367
    908
    46
    Feb 12, 2005
    New Joisey
    Thanks. Sounds like a pain. Maybe I should get a new blower motor...don't want to do this again.
