Blowing headlight bulbs every 4 days
Discussion in 'The BS Topic' started by jimrr, Dec 23, 2016.
  1. jimrr
    jimrr Veteran Member
    1,332
    306
    Jun 12, 2016
    sarasota
    Evening gentlemen. I have a 1992 f150. Same headlight bulb for 10 years. It blew. I replaced it with a 9007 sylvania bulb. ...blew it in 4 days. Replaced it, same result. Never touched the biob with my fingers either. Any ideas why Im frying bulbs? Sealed in nicely, no water intrusion. ....hasn't rained either. Perfect weather. Any ideas? Thx in advance. ..
  2. Knuckle Dragger
    14,869
    1,369
    Nov 2, 2002
    Waddell AZ
    Are you sure it's the bulb and not a burnt connector?
  3. Lowend
    15,009
    480
    Mar 25, 1999
    San Jose, CA, USA
    +1
    I'm betting you have a short
  4. camarolife78
    camarolife78 Veteran Member
    546
    Jul 22, 2014
    Gardner, KS
    IF the connector is good....I would check the running voltage. If the regulator goes sky high...it will blow your bulbs. I have had that happen to me personally.
  5. mrdragster1970
    7,822
    507
    Apr 12, 2007
    Same plug every time I highly doubt it's a regulator issue, but you never know.
    I would measure the draw, and check for exposed wire like Lowend said.
    Something might be rubbed through??
    Good luck.
  6. bourbon_scotch
    2,392
    136
    Jan 10, 2003
    USA
    hahahahahaha
  7. dirtmod08
    1,953
    549
    Jan 17, 2007
    Central Illinois
    I've had bad connectors play hell with me on those.
  8. bourbon_scotch
    2,392
    136
    Jan 10, 2003
    USA
    those bulbs are like $10/piece lol
  9. badazz81z28
    16,912
    500
    Las Vegas, NV
    Are you touching them with bare hands?
  10. jimrr
    1,332
    306
    Jun 12, 2016
    sarasota
    Connector is like new. I'm going to check voltage I guess. Both bulb's basically blew up. No glass left around them upon removal....
