Bolt-In Valve Stems
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by GoldenOne7710, Sep 9, 2019.
  1. GoldenOne7710
    4,889
    448
    Jun 23, 2004
    Athens, GA
    Who all uses them? Pros? Cons?
    I like the look of the short ones...just appears cleaner. I don't think access to the stem with an air hose will be an issue if I use them on my AR TT II's.
  2. badazz81z28
    17,157
    557
    Las Vegas, NV
    My forgelines have bolt in valve stems. I like them. Didn’t replace them when I swapped the tires, no issues
    GoldenOne7710 likes this.
  3. Bill70
    Bill70 Veteran Member
    234
    14
    Jan 8, 2012
    Phoenix, AZ
    I use them on my Vintage Wheel Works rims. No problems.
  4. Knuckle Dragger
    14,982
    1,440
    Nov 2, 2002
    Waddell AZ
    The only con I've ever heard is they can break if there is an impact where the rubber ones would flex. That said I've run them a bunch and never had an issue.
  5. ruthlessz28
    ruthlessz28 Member
    88
    16
    May 9, 2009
    crystal lake, il
    I use them on pretty much every thing, never had a problem. had a set way back when that the stem could unscrew and you only had a small "button" showing.
  6. Dave Nelson
    Dave Nelson Veteran Member
    4,480
    2,441
    Dec 19, 2003
    Vineland N.J USA
    They are usually rated for higher pressures also.
  7. flht99b
    flht99b Veteran Member
    317
    57
    Nov 28, 2014
    Knoxville, TN
    Has anyone seen the bolt on valve stems that would work with late model tpms senors such as the late model GM sensors?
  8. ruthlessz28
    ruthlessz28 Member
    88
    16
    May 9, 2009
    crystal lake, il
    yes napa and carquest both sell aluminum replacements for them might need a good counter man to find them but they are available
