Braided brake lines to Master Cylinder?
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by philip riou, Oct 7, 2019.
  1. philip riou
    philip riou New Member
    Mar 21, 2019
    I'm thinking of changing the copper lines to my master cylinder to braided ones for looks. Similar to this, http://waynes33.blogspot.com/2014/04/
    Can't seem to find many examples of this though, on any car. Is it a bad idea? Anyone done it?
  2. jamieg285
    jamieg285 Veteran Member
    1,307
    12
    Jul 15, 2004
    Luton, England
    The advice I was given was to stick with hardlines wherever possible and only use flexi for the short hops where they are needed.
    Even braided lines will have some degree of bulge (just less than rubber) which can affect braking performance. The more flexi you add, the more potential for bulging lines you'll have.
  3. budro6968
    budro6968 Veteran Member
    3,336
    543
    Apr 2, 2016
    Jax Florida
    Where do you have copper lines?
  4. philip riou
    Mar 21, 2019
    I've got braided on the last bit to the calipers, but copper coming off the master cylinder.
  5. CorkyE
    10,431
    502
    Kinda wondering that myself, hopefully OP meant steel. I replaced the rubber brake lines with braided, didn't realize that much improvement. I definitely will not replace the steel lines with braided though. If you need new lines, there are several vendors with quality products. I used Inline Tube when I switched to rear disc and changed to an aluminum master cylinder.
  6. budro6968
    3,336
    543
    Apr 2, 2016
    Jax Florida
    I never saw that b4. Usually hard steel curly Q to allow flex. Copper work hardens so it probably not a good thing to use it.
  7. CorkyE
    10,431
    502
    OP - original from factory was steel, not copper. I seriously doubt anyone would use copper for brake lines, copper won't withstand the pressure.
  8. berg2695
    berg2695 Veteran Member
    279
    53
    Nov 13, 2011
    AUBURN, WA
    I think nickel-copper brake line has a coppery hue. Maybe that's what it is. It would be light colored, though. Pure copper would be dark with age. If that's the case, don't drive it!
