Brake booster line - LS1
Discussion in 'High Tech Retrofits' started by Roggie, Jul 29, 2019.
  1. Roggie
    Roggie New Member
    25
    Jun 24, 2014
    United States
    Hey guys,
    Just finishing up my LS swap. '73 camaro, LS1 engine. Stock brake booster line from the car is a different size than the vacuum port on the LS1's intake. Curious how people have solved this issue? New port in the booster? New port in the intake? Some type of hose adapter?
    Thanks!
  2. Goat
    1,907
    44
    Jun 7, 2001
    moncure, NC
    I would say whichever of those three options you listed works best for you. If it were me I would go with the choice that used the biggest diameter hose...
  3. badazz81z28
    16,890
    499
    Las Vegas, NV
    Pop the plastic piece out on the booster and swap it to a larger one.
  4. 75Maro
    75Maro Veteran Member
    435
    18
    Mar 31, 2008
    Dallas,Tx
    I used an adapter fitting to go from the larger hose to the smaller
    Got it at HD
