Brake light switch - light
Discussion in 'Electrical Systems' started by Rugratman, Apr 17, 2019.
  1. Rugratman
    Rugratman New Member
    27
    Oct 25, 2018
    The parking brake light is staying on all the time.
    I can push down on the switch and it does nothing. Stay's on.
    Bad switch, or are these grounded somehow?
  2. Gary S
    22,010
    615
    The brake pedal switch grounds to turn on the light, but there is also a centering switch for the master cylinder on that same line. Either one can turn on the "brake" light. Unplug the wires to them one at a time to determine which one is turning on your light.
  3. Rugratman
    27
    Oct 25, 2018
    You were correct.
    When the pedal switch is grounded, and the master was plugged in. The light came on.
    I just popped the wire on the master. Thanks.
  4. Gary S
    22,010
    615
    If the switch in the master cylinder is turning the light on, it indicates a pressure problem between the front and rear brakes. You could have a fluid loss or defective master cylinder so you have only two wheel brakes and not all 4.
  5. Rugratman
    27
    Oct 25, 2018
    Will check that tonight. There is fluid, new in there. I will spin them, and check.
    Thanks again Gary.
  6. Jeep43
    Jeep43 Veteran Member
    1,192
    40
    Mar 30, 1999
    Connecticut
    That shuttle valve that trips the light in the Combination valve moves under line pressure when there is no/little pressure in the other circuit......
