Brodix -8
Discussion in 'High Performance Modifications' started by David_56, Mar 3, 2012.
  1. David_56
    David_56 Veteran Member
    585
    Jan 10, 2009
    Atascadero California
    I just picked up some brodix -8 heads from a swap meet and I dont really know a whole lot about these heads, Are these heads streetable?
    What size valves do these use? and where is the dang part number?
  2. Rick WI
    Rick WI Veteran Member
    10,400
    Jul 9, 2001
    Madison, WI
  3. David_56
    585
    Jan 10, 2009
    full on race heads?
  4. muscl car
    21,537
    559
    Jul 8, 2001
    High Desert of Hesperia Calif
    good cyl heads for a race engine that lives in the 3800 to 6800rpm with a compression ratio of 11.0:1 minimum ,and i would say they're not that streetable if you've got to run that mandated compression ratio
  5. mrdragster1970
    7,822
    507
    Apr 12, 2007
    Nice find.
    Just about anything can be made streetable.
    Good luck.
  6. muscl car
    21,537
    559
    Jul 8, 2001
    yup !!!:crazy:
  7. David_56
    585
    Jan 10, 2009
    Got the pair bare for 250.
    I have a vortec 377 (stock bore 3.75 stroke) with 5cc dished pistons, with a thin enough head gasket these would meet that 11-1 right?
  8. rustbucket79
    rustbucket79 Veteran Member
    9,076
    May 29, 2003
    British Columbia, Canada
    I believe the -8's have been around for many many years. Other than the larger 2.08 intake valve, they look like rather tame cylinder heads with only a 194 cc intake runner. Look like they come packaged with roller springs which may or may not work for you, but otherwise don't look any racier than Edelbrock/Patriot/etc.
  9. David_56
    585
    Jan 10, 2009
    Roller springs?
  10. K5JMP
    10,216
    8
    Oct 19, 2006
    MORTUORUM VENATOR - Z.R.T.
    if they are bare heads you get to set them up the way you want..
    but I would have them looked at very closely for that price...
    if they check out then you got a pretty good deal.:cool:
