BRP LS Swap kit, any one use it?
Discussion in 'High Tech Retrofits' started by CopperTop, Nov 30, 2010.
  1. Protour-Camaro
    Protour-Camaro Veteran Member
    2,111
    Feb 16, 2012
    California
    I get ya. I totally understand how important it is to have a kit to ensure it will all work together. I guess I have the opinion I have is because I bought mix/matched pieces and it all worked together. With Ebay adapter plates, Dynatech headers (when they were $300), and a APT crossmember.
  2. toddoky
    toddoky Veteran Member
    227
    Mar 5, 2013
    Bowling Green, KY
    Your answer is not quite right. Although 409ss will readily rust due to its low 11.5 percent chromium content, there are a number of dual stabilized ferritic stainless steels with substantially higher levels of chromium (17.5 to 19 percent) that do not readily rust, such as 439, 444, 446 and 18CRCB. You might actually be surprised to learn that 439ss has higher corrosion resistance than 304ss in cyclic high temperature applications. As far as magnetism is concerned, it has nothing to do with corrosion resistance. Admittedly, obtaining these more specialized ferritic grades is difficult and normally requires that it be purchased by the coil and be slit and rolled/welded into tubing by a tube mill facility.
  3. Fbird
    4,151
    692
    Feb 12, 2011
    atlanta, ga
    and lets NOT forget.....Stainless steel will only
    stain LESS. It will still rust regardless of what grade it is..... how long and how much varies but it's going to rust.
  4. Da-bigguy
    4,129
    272
    Jan 19, 2010
    Cypress, TX
    Ordered the BRP kit last night, we will see how it fits on my car.
  5. 5spd540
    12,389
    16
    Sep 19, 2009
    Guyton, GA
    What was in your kit
  6. Da-bigguy
    4,129
    272
    Jan 19, 2010
    Cypress, TX
    I got the mount and crossmember kit for the LS and 4L80e as shown if you click on the link I posted earlier.
  7. Da-bigguy
    4,129
    272
    Jan 19, 2010
    Cypress, TX
    Gotta love their shipping department! The kit should be arriving at my office on Wednesday. Unfortunately I will be offshore but once I'm back, time to start working on getting the engine and transmission installed!
  8. banaro79
    banaro79 Veteran Member
    268
    Dec 27, 2010
    hamilton, new jersey
    Three years on my kit headers look brand new
  9. gerno
    gerno New Member
    May 7, 2005
    Folsom
    Anyone have installed pics of the kit showing the headers clearance to the ground? Also, does anyone know which direction and how my the bell housing mounting location moves with this kit?
  10. OsborneConst
    OsborneConst Veteran Member Lifetime Gold Member
    1,011
    Oct 25, 2009
    Kalamazoo, MI
    This picture doesn't show ground clearance, but shows the relationship to the frame and transmission.
    I can't find any pictures of the intake to firewall clearance, but IIRC, they are 0 mounts, which keeps the back of the engine where the original SBC was so you could use an existing transmission.
