Buckeye79 and son not Camaro but S10 project "stretch"
Discussion in 'Project Progress' started by buckeye79, Dec 31, 2015.
  1. buckeye79
    buckeye79 Veteran Member Lifetime Gold Member
    639
    Dec 16, 2007
    Crestline, Ohio
    Cab back on and first test fit of the bed:
  2. buckeye79
    639
    Dec 16, 2007
    Crestline, Ohio
    We have done plenty more, I will be back later with what came next.
  3. Rich71
    Rich71 Veteran Member Lifetime Gold Member
    123
    Dec 19, 2014
    Earth
    Wow. Nice job, both of you. Awesome job on the splice, should be plenty strong.
  4. buckeye79
    639
    Dec 16, 2007
    Crestline, Ohio
    Thanks I hope so
  5. buckeye79
    639
    Dec 16, 2007
    Crestline, Ohio
    Inner and outer rocker panels, cab corners cut out ready for new ones to be installed.
  6. buckeye79
    639
    Dec 16, 2007
    Crestline, Ohio
    New rockers installed and painted:
  7. buckeye79
    639
    Dec 16, 2007
    Crestline, Ohio
    Minor rust repair complete on back of cab:
  8. buckeye79
    639
    Dec 16, 2007
    Crestline, Ohio
    New wheel arch panels welded in:
  9. buckeye79
    639
    Dec 16, 2007
    Crestline, Ohio
    Inside view of arch panels. We removed the outer wheel houses so that we could finish the inside of the patches as well. SPI epoxy followed by Duraglass, then finished off with black single stage enamel. I can't find the pictures but we also sand blasted the entire underside replaced one of the cross rails on the bottom of the bed finished with epoxy and single stage black:
  10. buckeye79
    639
    Dec 16, 2007
    Crestline, Ohio
    We then glued new outer wheel house panels in with 3M panel bond, put the bed back on the truck, filled and blocked the wheel arch panels and all other dents/dings. which leaves us where we are at today. Hopefully we will get a couple coats of epoxy on tomorrow and then finish up with 2K filler. Our goal is to get it painted next weekend.
