Budget Dual Fan Controller Setup / Taurus Fan Setup
Discussion in 'Electrical Systems' started by Aceshigh, Nov 20, 2010.
  1. Scott51
    Scott51 Veteran Member
    639
    74
    Jan 2, 2012
    New Zealand
    Not sure I'd call a setup that GM's used on 100,000's of cars "creative wiring" and a single Volvo controller will only get you one speed if you're running dual fans (the subject of my original post)
    No doubt the Volvo/BMW is a great setup with a big single fan, but if you want dual speed, dual fans, I think the GM style parallel/series circuit that was used in LS1's is a better alternative that can also be put together easily/cheaply with OEM parts.
  2. Fbird
    4,322
    767
    Feb 12, 2011
    atlanta, ga
    must have mis-read something as I was simply refereing to a single DUAL SPEED FAN (ie the Taurus, or Mark VIII) Not sure what GM put out as it doesn't really rank in the BAD ASS FAN catagory.
  3. Scott51
    639
    74
    Jan 2, 2012
    New Zealand
    Yeah I went with dual fans from an Australian EL - AU Ford Falcon (more common than Taurus' in this part of the world).
    Apparently these are the fans of choice for many guys with 1000HP+ burnout monsters and drifters and happen to be a very good fit on the camaro rad.
    Pretty good tech article here for those interested: http://www.aussiev8.com.au/holden-v8s/37776-ford-el-au-thermo-fans-into-hq-hz-holden-v8.html
    a search for LS1 dual fan wiring will also provide similar wiring diagrams, to the one I posted a few pages back.
    Top it off with the BMW temp sensor, grab a relay housing of your choice while you're at the scrapyard (I used a simple ford/mazda unit but I gather S10's are also a good option) and the HD fan relays from the car you pulled the fan from, and you should be good to go.
    Should probably post a new tech thread when I've got time :rolleyes:
  4. clay's70
    clay's70 Moderator Staff Member Lifetime Gold Member
    2,122
    60
    May 3, 2008
    Chesterfield, VA (Richmond)
    Another productive day at the junk yard.
  5. Turbo70Camaro
    2,142
    117
    Jan 7, 2005
    so cal
    Jackpot, clay save me the cleanest most legible one you have please, I will contact you tonight to get a spare from you.
    Jake
  6. blownbluebird
    blownbluebird New Member
    14
    Mar 27, 2010
    sc
    i have the the volvo relay and bmw sensor and fan. anything else i need before i start. do i need a relay to kill power with key off? 23 pages and i still not sure.
  7. clay's70
    2,122
    60
    May 3, 2008
    Yes, that is what i did.
    The single relay in the left is supplied by a lead that is only hot when the
    ign. is on. The negative lead from the temp switch is turned on and off
    by this relay.
  8. blownbluebird
    14
    Mar 27, 2010
    sc
    do you have a diagram of how you wired the relay into the mix?
  9. clay's70
    2,122
    60
    May 3, 2008
  10. nachomax
    nachomax New Member
    Jul 27, 2013
    Los Angeles, CA
    Hi Clay,
    Sorry to revive an old thread. I bought the Volvo relay from you and received that wiring diagram. I opted to use the LEDs inside the dash. My problem is that they stay on. Somehow the temp switch is always getting power from the Volvo controller "IN" for both "1 and 2" regardless if the ignition is ON or OFF. I have the additional Bosch relay to the temp switch ground and the fan only turns on with Ignition on the ON and ACC position. I don't want to go through the hassle of drained batteries and I know that LEDs don't suck too much current, but I rather not see them ON when the Ignition is in the OFF position. Would it be safe to tap them into the 1 and 2 leads that feed the fan?
    Thanks,
    Nacho
    PS. The fan works great cooling my 455 Pontiac Firebird.
