C&R LS Radiator
Discussion in 'High Tech Retrofits' started by badazz81z28, Jun 14, 2019.
  1. badazz81z28
    16,180
    378
    Las Vegas, NV
    Correct, the only reason I swapped was due to my overheating PS pump issue. I was going to install a external cooler, but there is just really nowhere to mount a good one and the zip tie through the radiator seemed like it would be inefficient. I’m sure C&R could custom make the fitting location, but I’m scared to ask how much lol.
    If you look into the tank, you can see the coolers.
    dave@ztech likes this.
  2. 76z28
    76z28 Veteran Member
    1,937
    37
    Jun 29, 2009
    bakersfield
    I don't remember if i asked this or not, what intake are you using? I am trying to replicate something similar so I can get cooler air into my filter... right now I am looking at 150 IAT which kills power.
    That radiator looks awesome though. I wish I could go with something like that. It is definitely a work of art.
  3. 76z28
    1,937
    37
    Jun 29, 2009
    bakersfield
    Did you get this running? How did it work for you?
  4. badazz81z28
    16,180
    378
    Las Vegas, NV
    E797C7C9-462C-44B5-81F8-8954D68CE0D3.jpeg 643497D4-99E4-4BA5-889F-8CBD12A7FCE8.jpeg
    I did. I also installed the oil cooler components which caused a lot of the delay. While I was at it, I finally installed my Holley fuel rail. For my air intake I’m using Spectre. I also cut a 4” hole in the inner fender for fresh air.
    roadrace2, dave@ztech and 76z28 like this.
  5. 76z28
    1,937
    37
    Jun 29, 2009
    bakersfield
    Got the dewitts radiator/fan set up in. Works great so far!(just letting it idle in the garage since I can't get the car out due to construction materials in the way).
    Going to keep the temp sensor(on at 210 off at 195).
    Thank you!
    roadrace2 likes this.
  6. 76z28
    1,937
    37
    Jun 29, 2009
    bakersfield
    Got the car out. Seems to like to run 195 to 205 no matter what even driving or idling! Not a big concern but I do need a new alternator
