C5 brake conversion anyone ?
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by 72BIGBLOCK, Sep 30, 2018.
  1. 72BIGBLOCK
    72BIGBLOCK Veteran Member
    2,405
    112
    Feb 2, 2008
    SF
    Hi everyone I’m at the point where I need to look at brake options in the car since I don’t have any brakes at all.
    I priced out baer but out of price range and I don’t really think I need something that high end
    Wilwood was a bit better but I still think I don’t need anything that fancy
    I’m running a l76 (similar to an ls2) so I was thinking maybe a c5 conversion?
    What do you think or recommend?
    I’d like to spend between 800-1800 for front and rear of possible.
    All I have are the spindles and a brake booster from a 79 trans am along with master cylinder and combination valve
    Thanks everyone
  2. BonzoHansen
    19,637
    902
    Jun 1, 2005
    Scott from Hamilton, NJ
    Kore3
  3. 72BIGBLOCK
    2,405
    112
    Feb 2, 2008
    SF
    I looked at kore 3 and they were priced the same as wilwood.
    If I have to go over 2500 I rather go with wilwood which brings me back to square one
  4. BonzoHansen
    19,637
    902
    Jun 1, 2005
    Buy the brackets from him then source the OE parts elsewhere.
  5. Lowend
    15,155
    550
    Mar 25, 1999
    San Jose, CA, USA
  6. badazz81z28
    17,382
    604
    Alabama
    I would never recommend Wilwood. Look into Baer or the Kore3 set-up
  7. John Wright
    14,716
    216
    Aug 9, 2002
    Rustburg, Va
    Like the others have said, buy the brackets and hardware from Kore3 or Keith at Custom Works, and grab a set of calipers off ebay from someone upgrading their brakes on their C5. I have around $800 total in mine and that was buying the rear brackets twice....once without an ebrake from Kore3, and then again with the ebrake from ebmiller.
  8. hogg
    hogg Veteran Member
    3,168
    27
    Dec 29, 2000
    pegram,tn.,cheatam
    99 and up blazer rear brakes about 250 or #300 and use what you already got. send me what money you got left.
  9. Charlie1800
    Charlie1800 1981 Z-28
    19
    Jul 27, 2014
    Lexington,SC
    Check out http://bigbrakeupgrade.com/ Scott is awesome, and I sent him a pair of CPP 2" drop spindles and he changed the brackets to accommodate gen 6 brakes. The theory being that going forward, parts, etc will be simple and inexpensive to replace (along with superior stopping power). Corvette C 7 & 5 rotors and we had to make the emergency brake cable set up. Including all the parts, within your price range. I did have to lose my 17" Year One Rally wheels, but def. worth it. Still waiting on the wheels to come in, as I had to order custom offset from American Racing. I'll advise with pics when that's done IMG_1202 (003).JPG IMG_5392 (002).JPG
    72BIGBLOCK likes this.
  10. Schubitzky
    Schubitzky Veteran Member
    325
    Mar 10, 2003
    Maryland
    +1 for Kore3. Get the brackets and hubs if you can afford them, modify your spindles, and get calipers, abutments, rotors on your own either at rock auto or a parts store. Check out corvette forums too. Sometimes you can find guys giving them away to upgrade their cars. Just make sure you pick a size and go with it, JL9, Z51, Z06 are all a little different.
    70 Proof likes this.
