C5 Front Brakes Conversion
Discussion in 'High Tech Retrofits' started by DougMC, Aug 6, 2006.
  1. CTSmechanic
    CTSmechanic Veteran Member
    490
    Jan 2, 2004
    North Carolina
    Dude forget the C5 go with the C6 ZO6 theres a guy on Ls1Tech that did it its freakin awesome
  2. Teetoe_Jones
    Teetoe_Jones Member
    56
    Apr 30, 2001
    Las Vegas, NV
    Harley you bastard. ;)
    Tyler
  3. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
    Give us the link.
    I'd like to check that out myself, but I'm sure the price is probably double.
  4. 3_z28camaro
    3_z28camaro Veteran Member Lifetime Gold Member
    4,448
    Dec 17, 2004
    Acton, CA
    C6 Z06 would be very cool, but really expensive. Plus I think you might have to get 18" or more wheels. I like my C5 brake swap, it hauls the car down no problems.
  5. zbugger
    zbugger Veteran Member
    3,773
    Aug 25, 2002
    My own personal hell...
    Try triple. I think the brakes go for around 1200 for the set. I'm not sure if that even includes the rotors. Then you'd need the modified spindles, hubs, and brackets. And then I've heard of people having trouble with pad wear. But it does look cool.....
  6. DougMC
    DougMC New Member
    Jul 29, 2006
    IL
    Thanks!
    Thanks guys, lots of good info to get me started on a plan. I'll check out www.pro-touring.com, Aces. I live in Jerseyville which is about 30 miles north of St. Louis.
    Gives a good overview. Thanks Boyd.
    An alternative solution, thanks
    Thanks, checking out kore3.com looks like they have everything needed. A rear disk conversion caught my eye there too, but thats another topic...
    This sounds interesting but I'm guessing it would cost more than I'm willing to pay. ;)
  7. driftwood
    driftwood Veteran Member
    2,026
    Mar 4, 2002
    07882, NJ
    I thought that would be good also ,but after browsing corvetteforum.com ,all I saw were complaints.Most said it was no better than a wilwood or stock c5 setup,definitely not worth the $1200 or so in parts.
    http://z06vette.com/forums/showthread.php?t=91237&highlight=brake+swap
    with more links inside,very heavy set up.Alternatives are listed also from stoptech and wilwood.
  8. 3_z28camaro
    4,448
    Dec 17, 2004
    Acton, CA
    I also did the C5 rear disk conversion too, it looks great having disks in the rear. Not to mention they perform better than drums.
