Calculating Pulses Per Mile
Discussion in 'High Tech Retrofits' started by Keaton, Sep 16, 2019.
  1. Keaton
    Keaton New Member
    Sep 16, 2019
    I figured it out, I had to mess around with the dip switches on the back of gauges. It wasn’t getting enough signal under 20 mph with the new transmission, and after I messed around with the switches it worked like a champ. Thanks for the replies though.
  2. ULTM8Z
    ULTM8Z Veteran Member
    9,320
    457
    May 19, 2000
    Los Angeles
    Sweet... glad you got it figured out
  3. ErikNORCAL
    ErikNORCAL Veteran Member
    1,141
    12
    Aug 6, 2003
    now in VA
    Keaton,
    What NVU gauges do you have? About to install my genII NVU cluster and have been reading up on the Speedo section... my head is swimming.
    I’m guessing the 2 wire sender is ford/Tremec specific? Are you fuel injected by chance, read that the 2 wire generates a sine wave?
