Calling all Camaro nuts
Discussion in 'Troubleshooting & Diagnosis' started by Scaleytail, Jul 6, 2019.
  1. Scaleytail
    Scaleytail Member
    65
    8
    Jun 12, 2016
    North Aurora, il
    1979 Camaro ....turn the key to start , release the key....the starter continues to run --ended up putting it in gear until the negative battery connector fried. I can release the key and even pull it out and the starter keeps cranking. why isn't the starter releasing?
  2. Gary S
    22,018
    625
    You will need to do some troubleshooting. Does the "start" power at the starter go away when you release the key? If you get the answer to that question, you know which way to go to look for the problem.
  3. bourbon_scotch
    2,264
    101
    Jan 10, 2003
    USA
    You should really get one of these
    Scaleytail likes this.
  4. tom3
    tom3 Veteran Member
    11,668
    264
    Aug 1, 1999
    ohio
    I'd guess the starter solenoid is fried. Putting in gear and letting clutch out should have killed the start circuit to the solenoid.
  5. Scaleytail
    Scaleytail Member
    65
    8
    Jun 12, 2016
    North Aurora, il
    That makes sense --it is wired to not start in gear.
    Plus, now that I think about it .....it wouldn't start the day before after driving it about 30 minutes 90 plus degrees... got home and it sat in the sun on the hot asphalt which probably really heat soaked the heck out it.
    Later that night and next morning it started fine. Til I drove it a bit and parked it n the driveway on another very hot day-this time the soeniod must have stayed engaged due to the heat punishment.
  6. Zspoiler
    Zspoiler Veteran Member
    3,079
    230
    May 6, 2012
    Federal Way, Washington
    Just make sure the starter switch on the column is adjusted as well.as well as checking the wiring.
  7. Scaleytail
    Scaleytail Member
    65
    8
    Jun 12, 2016
    North Aurora, il
    Adjusted as in on/off operation?
  8. Zspoiler
    3,079
    230
    May 6, 2012
    That as well
  9. cadillac_al
    cadillac_al Veteran Member
    775
    67
    Apr 22, 2015
    Maine
    Tom nailed it. I would just buy a whole new starter.
  10. Scaleytail
    Scaleytail Member
    65
    8
    Jun 12, 2016
    North Aurora, il
    ..........and yes it was the starter. The solenoid not releasing really threw me for a loop. Thanks for guidance.
    Smokey15 likes this.
