Calling all guys that part out cars....
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by KEVS79, Oct 15, 2015.
  1. KEVS79
    KEVS79 Veteran Member
    2,465
    Mar 3, 2008
    GLADSTONE, MO
    I am going to be snagging a rear end out of a TA in a field. What is the fastest way to yank it out? I was thinking jack up the rear of the car, take a sawsall to the front and rear spring eye bolts and shocks, unbolt the sway bar from the frame and roll the whole thing out drive shaft and all. Any other suggestions?
  2. Dogwater
    Dogwater Veteran Member
    926
    Dec 23, 2010
    SanAntonio Tx
    I'd bring the sawall anyhow, but I'd try to unbolt first. Hose everything down with penetrating oil an beat the chit out of those bolts with a BFH then respray. Or you can cut off those big U bolts then it come right out. Might need some muscle to pull it out, weights about 80lbs without the brake calipers on it.
  3. Matt T
    Matt T Veteran Member
    762
    Nov 12, 2003
    Pawtucket, RI, USA
    Fastest--cutting torch, if you can be certain there is no gas or fumes left in the tank, but I'd try to do it the right way first.
  4. Twisted_Metal
    27,285
    1,122
    Cutting eye bolts will be a PITA! Avoid if possible.
    If the car can be lifted and supported by the rear frame... You can pull the rear out through the leafs from one side.
    Bolts, shocks, e-brake and brake lines is all you have to deal with that way.
  5. KEVS79
    2,465
    Mar 3, 2008
    GLADSTONE, MO
    Yep, might be easier to just unbolt than mess with cutting that's for sure. But will have the sawsall on hand just in case. I don't have access to a cutting torch unfortunately.
  6. Skip Fix
    Skip Fix Veteran Member
    2,193
    24
    Mar 21, 2007
    Katy,Texas
    Save the sway bar and brackets for it also.
  7. KEVS79
    2,465
    Mar 3, 2008
    GLADSTONE, MO
    I was going to grab the front bar also if it is the thick ws6 bar. Of course will get all the disc brake related stuff also.
  8. Gary S
    22,775
    914
    Unbolting the springs at the axle is easier than cutting the springs. Likewise, it is easier to unbolt the swaybar than it is to try to cut it loose. The only thing I cut is the rubber brake line, and the front parking brake cable. Save the rear ones.
  9. 351maverick
    351maverick Veteran Member
    3,693
    467
    Aug 11, 2010
    erie, PA
    unbolting? what is that? LOL
    cut off wheel on a 4 1/2" angle grinder...
    cut the two bottom shock bolts
    sawzall (with a good, new blade or two) the ends of the leaf springs & slide that mother out
    I do not like to be underneath a junk car like that more than I have to
  10. Protour-Camaro
    Protour-Camaro Veteran Member
    2,111
    Feb 16, 2012
    California
    What, are you stealing it? What's the hurry? I suggest you just un bolt it. If all you want is the rear (No springs), its shouldn't be tough to remove it.
