Cam Swap versus Hydro Boost
Discussion in '1970 - 1973 Specific' started by chiefburns, Feb 14, 2020.
  1. chiefburns
    chiefburns New Member
    11
    Feb 4, 2020
    The guy I bought my 72 from built the engine with the intentions of putting a blower on it, which I am not going to do. My problem is with this huge cam I have very low vacuum and stop and go brakes are almost non-existent. I want to be able to drive it anywhere I want (hense the EFI install) without having to worry about rear-ending someone due to no brakes. So I need to decide whether to swap out my cam with a more streetable version to give me more vacuum/brakes or dump another grand into it and add hydro boost. Thoughts?
  2. G72Zed
    G72Zed Veteran Member
    1,260
    301
    Sep 8, 2015
    Since your not going going to put a blower on it, you now have the wrong cam in there. I would change the cam that fits your application and yours needs and requirements like power brakes.
    I use a "large" cam because it's what wanted, but use manual brakes to eliminate the low vacuum issue, that "could" be an option for you, just saying. I drive my car very regularly, no issues with manual brakes, but it does take more leg pressure, but not much, but I also use a carb.
  3. chiefburns
    11
    Feb 4, 2020
    We stay in contact with each other and when I told him that I was putting EFI on it he said that I should probably change the cam.
  4. flht99b
    flht99b Veteran Member
    312
    55
    Nov 28, 2014
    Knoxville, TN
    Definitely change the cam and whatever cam grinder you use let them know as much specifics about the engine, drivetrain and especially let them know you are going EFI and intended usage of car.
    Zstar likes this.
  5. Zstar
    Zstar Veteran Member
    1,475
    313
    Mar 23, 2014
    Ocala, Florida
    I changed the pure race cam and added hydroboost. No problems now.
  6. jeff swisher
    jeff swisher Veteran Member
    1,463
    441
    Apr 26, 2018
    Yukon Oklahoma
    Hydro boost to me look horrible and I wonder why people do not use an electric vacuum pump.. many manufactures use them Cadillac ..Volvo.
    I would think that would be cleaner and easier.
    If you are idling at say 800 rpm sometimes turning it up to 1000 will be just enough to solve the issue.
    I myself would go electric vacuum pump .
  7. chiefburns
    11
    Feb 4, 2020
    I found an electric vacuum pump on Jegs for $117 bucks, which is a whole lot easier than a cam swap, especially for a non-mechanic. I'm gonna do some research on it but that may be the way I go. Thanks for the suggestion!
    jeff swisher likes this.
