Can’t believe my luck...what happened?
Discussion in 'The BS Topic' started by badazz81z28, Sep 14, 2019.
  1. xten
    xten Veteran Member
    2,709
    1,482
    Sep 24, 2014
    Pittsburgh, Pa.
    Is that a bottoming tap you are using? Looks like the wrong tap for a blind hole. You need the concentric "bottoming tap",not the tapered one. You can't start cutting threads with the bottoming tap, but with a blind hole you need to finish with it if the threads go anywhere near the bottom. Also maybe a shaving still attached to the threads that's hiding in there.
    https://www.mcmaster.com/bottoming-taps
  2. Twisted_Metal
    26,875
    904
    Looks to me like it wasn't tapped all the way to the bottom of the hole.
    Coffee break or shift change and someone didn't bottom tap the last blind hole on that part? :screwup:
    You should have plenty of thread contact with that bolt but you won't get it seated unless you have a bottoming tap to finish cutting threads to the bottom of the blind hole.
    I would shorten that one bolt and use it.
    Run a die down the bolt, grind it off and run the die back off the bolt so you have straight threads on the end.
  3. badazz81z28
    16,365
    404
    Las Vegas, NV
    What I ended up doing was running a tap down the hole. Having not looked, I’m not sure how deep the threads originally were. It cleaned it up decent, just ugly. I did assemble it yesterday...torqued to 65ftlbs, some scary moments where I thought it was going to let go. By my measurements. I have about half the threads engaged questionable threads and another half in perfect threads with a new bolt. (About .425”)
  4. dcozzi
    dcozzi Veteran Member
    2,905
    322
    May 1, 2002
    Phoenix, AZ
    This^^
  5. badazz81z28
    16,365
    404
    Las Vegas, NV
    Replacing the bolt wasn’t an issue. It’s was the threads in the housing that’s scary
  6. 80sz
    80sz Veteran Member
    3,138
    405
    Feb 2, 2014
    Buffalo,n.y.
    Glad you got her . Looks like wasn’t tapped to depth and you were making new threads with your bolt.
  7. badazz81z28
    16,365
    404
    Las Vegas, NV
    I have OCD...But this is what the threads looked like after I ran the tap. Mind you, the bolt coming out transferred puic1.jpg metal all the way out. Not pretty...
  8. dave@ztech
    3,318
    686
    Mar 27, 2016
    NY
    I thought, you got the DSE kit, wasn't all of the parts tapped and ready to go? Also what width rear did you go with? Really like the looks of that setup, just not crazy about the price.
  9. badazz81z28
    16,365
    404
    Las Vegas, NV
    That is the DSE kit. Overall flange to flange is 56.250”
  10. dave@ztech
    3,318
    686
    Mar 27, 2016
    NY
    I thought that the rear on a 71 Camaro or any was 55.25 flange to flange? Right?
