Can someone buy me a bolt?
Discussion in 'The BS Topic' started by badazz81z28, Sep 22, 2019.
  1. badazz81z28
    16,588
    438
    Las Vegas, NV
    So remember when I was looking for 21mm bolts and everyone had 22mm? So I bought bolts from ACE and needed 4 and they only had 3. Waited 2 weeks and now I get the 4th bolt and it has a 21mm head versus the 22mm they had!! Wtf!!
    I need a 22mm head 14x2.0, 50mm length, 10.9 with “JH” on the head. Anyone live close to an ACE that can buy me one?
  2. bfmgoalie
    bfmgoalie Veteran Member
    1,897
    220
    Jun 14, 2008
    Gansevoort, New York
    Ace normally purchases their fasteners from Hillman Fastener. I ran a distribution center for them a million years ago. Go to Hillman on their website and see what they can do for you.
  3. bourbon_scotch
    2,356
    122
    Jan 10, 2003
    USA
  4. badazz81z28
    16,588
    438
    Las Vegas, NV
    Considering 3 bolts from ACE say JH on the head are 22mm wrench size and today they are SFC with 21mm heads.
    I’m NOT looking to disassemble the right side of the car to swap bolts out. I’m sure another ACE has the bolts I originally purchased. I only need one.
  5. bfmgoalie
    1,897
    220
    Jun 14, 2008
    Have the UPC/SKU part number? I'll look it up and see who carries them locally. Lowes also carries a full array of Hillman products.
  6. 72'z'steve
    72'z'steve Veteran Member
    941
    91
    Oct 15, 2000
    waukesha wi usa
    I'll print off your specs and look at ACE tomorrow morning,right next to the Meijer I have to grocery shop at I'll take my caliper with for head size,I go about 8:30 cst I'll P.M. you about 10 am cst with what I found-Later Steve!!
    P.S. if they have exactly what you have I'll get one,or do you want a second or third for a spare-your luck with bolts hasn't seemed to be the best!!!
    I'll post also if they do or don't have here
  7. badazz81z28
    16,588
    438
    Las Vegas, NV
    All the normal stores like Lowe’s max out at M12.
    Thanks Steve, I appreciate it!
  8. sprink
    sprink Veteran Member
    499
    118
    Apr 27, 2008
    ffx, va
    I'm close. I'll check also.
  9. Lars_2Gen
    Lars_2Gen Veteran Member
    595
    139
    Dec 29, 2017
    Fullerton, CA
    I have an Ace down the street... I'll check tomorrow.
  10. dave@ztech
    3,399
    703
    Mar 27, 2016
    NY
    I have an Ace, across the street from me, I will check today when I get back from work
