Can someone buy me a bolt?
Discussion in 'The BS Topic' started by badazz81z28, Sep 22, 2019.
  1. ULTM8Z
    ULTM8Z Veteran Member
    9,119
    333
    May 19, 2000
    Los Angeles
    Check McMaster Carr. They have everything.
  2. ZEN357
    ZEN357 Veteran Member
    383
    70
    Feb 12, 2018
    Lowes normally carries Hillman products. They should have what you need, if not have you tried a Tractor Supply?
  3. badazz81z28
    16,567
    430
    Las Vegas, NV
    Lowe’s doesn’t sell grade 10.9 fasteners nor do they go to the size I’m looking for. The hardware stores around here, the same scenario
  4. bfmgoalie
    bfmgoalie Veteran Member
    1,891
    220
    Jun 14, 2008
    Gansevoort, New York
    Maybe I'm missing something. You bought these bolts from an ACE in your area. You received 3 which were correct and one obviously wasn't. These bolts are supplied by Hillman, hence they do have the bolt you're looking for. If not, you wouldn't have received 3 correct ones.
  5. badazz81z28
    16,567
    430
    Las Vegas, NV
    Yes, at ACE as they are the only ones that sell 10.9 fasteners in that size.
    The box of fasteners at ACE was qty of 3,
    22mm heads, 10.9 with “JH” on the head. Waited for more to come in...the new box they have were 21mm heads, 10.9 with “SFC” on the head. So I don’t know if they sourced them from somewhere else or what.
  6. 72'z'steve
    72'z'steve Veteran Member
    934
    91
    Oct 15, 2000
    waukesha wi usa
    I stopped at 2 aces' here both had black oxide versions of your bolt,not plated,not Hillman either they did say JH 10.9 though.Talked to the old guy in charge of the dept,said they changed vendors-its something with a "m" all the 10.9 bolts are black the guy comes weekly and restocks,they only "carry" 4 at a time in the slot in the box .I stopped at true value,even menards-both had 8.8 bolts and the cut was so bad on them they would cut your finger,I wouldn't put them on a coaster wagon.
    If it were me,Id order what I need from mc master carr like mentioned above,I use them at work all the time they are quick to ship have quality items and they will be the same.-Did my best,looks like you are "bolt stricken" LOL. Maybe someone else has better luck in their neck of the woods Later Steve!!
  7. flht99b
    flht99b Veteran Member
    205
    37
    Nov 28, 2014
    Knoxville, TN
    Have one in my hand, only one the Ace near me had.
  8. flht99b
    205
    37
    Nov 28, 2014
    Knoxville, TN
    22mm head. It's $3.39, does that sound and look right?
  9. flht99b
    205
    37
    Nov 28, 2014
    Knoxville, TN
    Purchased it, if it's what you are looking for, PM your address.
  10. sprink
    sprink Veteran Member
    499
    118
    Apr 27, 2008
    ffx, va
    IMG_5015.JPG This is as close as I got. Head takes 18mm wrench.
