can't decide if its worth it 2.73 open to 3.42 posi
Discussion in 'Transmission & Driveline Topics' started by 351maverick, Sep 11, 2019.
  1. 351maverick
    351maverick Veteran Member
    3,614
    390
    Aug 11, 2010
    erie, PA
    in my 3rd gen 88 Firebird Formula
    currently has a one wheel peel 2.73 10 bolt
    a bunch of local guys have 3.42 posi 10 bolts out of T56 6 speed 4th gens ready to bolt in for less than $300
    my 18" rear tires are getting old & hard...one will often spin not even laying into the gas much
    4th gen rears are basically a bolt in, and it would eliminate my 2" wheel adapters in the rear
    2.73 to 3.42 isn't that big of a difference...I'd much rather 3.73 or even 4.10 (700R4) but nowhere near as cheap as a factory assembly
  2. Coadster32
    1,638
    133
    Oct 2, 2013
    Milford,CT
    I'm thinking that you have more cars apart than anyone else on the board on a daily basis, so the effort shouldn't be too great for you. For the price, this seems like a win to me. I understand about the gearing not being that different. If you don't need posi, and you want the taller gears, then hold off, and sell some more car parts till you raise up the cash. Perhaps get the other rear, and put in new gears before you install it?
    351maverick likes this.
  3. big gear head
    big gear head Veteran Member
    6,182
    84
    Jul 30, 2001
    Central City, Ky.
    The 3.42 is usually pretty much perfect for a 3rd gen. The 700R4 transmission has a 3.06 first gear which is usually too much when going to a 3.73 or 4.10. The 4th gen width seems like it will be perfect for your wheels. I think it's a good swap.
  4. ZEN357
    ZEN357 Veteran Member
    383
    70
    Feb 12, 2018
    I think it would be a good swap since it's an automatic transmission. When I owned my 91 Z/28 I wen to 3.73 in the rear but I had a 5-Speed. Made a world of difference. I had a friend do the swap at the time and install a locking rear. He only charged me $100 to do the swap and I helped him so I would learn how to do it.
  5. xten
    xten Veteran Member
    2,885
    1,645
    Sep 24, 2014
    Pittsburgh, Pa.
    I'd try it Mav. $300 is cheap. I think that would be a big bang for the buck. Besides, the 3:42's with that 3:06 first gear will feel pretty good. Had 4:10's with a 700R and first gear was useless. Went to 3:89's (9") and wish I would have gone more shallow.
  6. Bandit723
    Bandit723 Veteran Member
    3,148
    463
    Oct 1, 2016
    Waupaca WI
    I recently went from 3.73's to 3.42's (700R4) definitely made the 1st gear feel much better.
  7. biker
    biker Veteran Member
    840
    70
    Dec 7, 2014
    New Liskeard Ontario Canada
    Definitely worth it.
  8. 351maverick
    3,614
    390
    Aug 11, 2010
    erie, PA
    you guys are inspiring - thank you
  9. Twisted_Metal
    26,996
    968
    That's the swap I made... 2.73 peg-leg to a 3.42 Eaton posi. (The 25% difference in rear gear ratio is quite noticeable.)
    I also installed a 2004R (0.66 OD) transmission so the final ratio in OD is around 2.25 for highway cruising. (2000 RPM @ 70 MPH)
    The 7004R has a similar OD ratio (0.7) so I would expect around 2100 RPM @ 70 MPH with 3.42 gears.
    Downshifting (via throttle/TV cable) is much more fun with the 3.42 gears. ;)
  10. Zspoiler
    Zspoiler Veteran Member
    3,231
    260
    May 6, 2012
    Federal Way, Washington
    3:42`s are a good compromise gear .You get good acceleration and decent gas mileage. I have a set in both my 1979 -28 with a 4 speed supercharged 377 small blok and a 1981 El Camino SS 350 small block turbo 350 .and both get around 22-5 MPG. with a 26 inch tall tire at 2500 rpm
