can't decide if its worth it 2.73 open to 3.42 posi
Discussion in 'Transmission & Driveline Topics' started by 351maverick, Sep 11, 2019.
  1. black_aerocoupe
    504
    16
    Jun 3, 2008
    McD's @ the Pavillions, AZ
    That's the textbook ideal rear for your (as-stock) vehicle unless you need to go back and run 0 offset wheels. Or need a strength upgrade.
    An '88 Formula starts life with a choked-head-intake ports engine, or a choked-port-intake-mani that is matched better to 3.42 than it would be to 4.10.
    Drivability around town and country is better with a 3.42. Unless you're putting mega hwy miles on, or otherwise prioritizing mileage and need to keep the 2.73, go for it, absolutely.
    A V8 '98 was an Auburn, with an SLP Torsen option. Ideally, a '99-02 rear has a standard (no frictions) Torsen, unless the car was SLP-"upgraded" to an Auburn those years.
    Your tach, speedo, math or all 3 are off.
    dave@ztech likes this.
  2. SRGN
    SRGN Veteran Member
    672
    234
    Feb 20, 2009
    Central NJ
    Do it. You will notice the difference, and the car will be more fun to drive. I've gone from a 2.73 to a 3.23 and noticed a vast improvement. Plus the 4th gen rear disc brakes are much better.
  3. big gear head
    big gear head Veteran Member
    6,170
    78
    Jul 30, 2001
    Central City, Ky.
    Just a warning, if you have been doing one wheel burnouts and the tread on the right tire is less than the tread on the left tire then you need to replace the tires. If you use a LSD with tires that have uneven tread wear, unequal air pressure or different size tires then you will wear it out quickly and cause the oil to run hot.
  4. GoldenOne7710
    4,765
    377
    Jun 23, 2004
    Athens, GA
    I did a 2.56 swap to 3.42 ratio behind a TH350. Made all the difference in the world. Can't go wrong behind a 700R4.
    351maverick likes this.
  5. 80sz
    80sz Veteran Member
    3,155
    415
    Feb 2, 2014
    Buffalo,n.y.
    You done yet ??? What’s takin so long
    70-camaro likes this.
