carb idle question
Discussion in 'Engine Topic' started by cutty, Jun 10, 2016.
  1. cutty
    cutty Veteran Member
    342
    Dec 12, 2008
    ontario canada
    hi guys, got a question with the battle ive been having, ive got a 650 holley double pump on my motor, specs are 10.5 to 1 comp roughly, double hump heads, cam is a 540/540 lift, vac in idle in park is 9, gear 7, i cant get it to idle in park lower then 1100 gear 900 rpm,any lower it stalls, tested and retested for vac leaks, theres none, specs on carb are front jets 68 rear 78 front squirter 28 rear 31, power valve is a 4.5, ive tried putting my thumb over front bleeds, dies right away, idle mixture screws are 2.5 full turns,( just a 2 idle mixtures) it works dont get me wrong, but would like my idle down abit, timing at idle is 16, 36 total by 2800, any ideas?
  2. CorkyE
    10,453
    508
    What's full specs on that cam? Mine doesn't like to idle much below 1K either. I have found that if you can increase base timing without going over on total timing, you will get a better idle. Also, going to assume you're not using full time vacuum advance either, that's hard to get a consistent idle with a big cam.
  3. G72Zed
    G72Zed Veteran Member
    1,258
    299
    Sep 8, 2015
    X2 ^
    Mine likes a min. of 22* at 1,100 rpm, 38* all in by 2600 rpm. I play with the spings only. I even tried 24-26* at 1,100 engine loves it, great throttle responce.
    I think allot of "carb issues" are actually timing issues, that's just my thinking.
  4. 80sz
    80sz Veteran Member
    3,216
    429
    Feb 2, 2014
    Buffalo,n.y.
    I got same #s also, Almost same setup,540 cam,10.9-1 comp,vac same,rpm same,I can go little lower if I didn't have electric fan,it kicks on bogs me down 50-75 rpm
