Carbed LT1 questions
Discussion in 'High Tech Retrofits' started by Quick Nick, Jan 19, 2006.
  1. Quick Nick
    Quick Nick Veteran Member
    679
    Jan 22, 2005
    Kalamazoo, Michigan...home of, well, nothing..
    Great timing on this section!
    A buddy has a 95/96 LT1 Caprice (cop car ;) ) and wants to stuff the engine/trans into his S-10 as cheaply as possible. We can keep it injected the cheap way by pulling all the needed wiring off the donor car, but what about just using the LT1 carb intake from GM Performance Parts? Anyone have any info or used it before? I've looked and found no-one who has. Any cons to using this intake, other than no more fuel injection?
    Thanks!
  2. PhilM
    PhilM Veteran Member
    1,274
    Aug 30, 1999
    Pac NW
    Nick,
    I have a 95 camaro that had a dropped valve in it. I yanked the LT-1 and put in a refreshened one. The old motor went in a 67 camaro. He put a intake and a edelbrock carb on it. He says he bought everything from skoggin dickey for the retro fit and was not that expensive.
    Hope that helps....
  3. Quick Nick
    679
    Jan 22, 2005
    Thanks Phillip :cool:
  4. fbodyfreak
    fbodyfreak Veteran Member
    160
    Oct 18, 2005
    Briceville, TN
    My friend put this setup on a '69 Camaro, and it runs really good. I'm not sure what all he changed, but I do remember he was running an HEI distributor, you have that option with the carb intake. All LT1 cams have the drive for rear mount distributor, so you can do away with the opti-spark. hope that helps some.
