Challenger tr6060 in 2nd gen
Discussion in 'High Tech Retrofits' started by Joey73RS, May 18, 2019.
  1. Joey73RS
    Joey73RS Member
    30
    Oct 20, 2017
    I found a tr6060 out of a scatpack challenger for sale and was wondering if its any different from a Camaro 6060. If not what kind of modifications would be needed to make it fit in a 2nd gen?
  2. DB Z28
    DB Z28 Veteran Member
    558
    41
    Nov 30, 2003
    Fond Du Lac
    Is The Bell housing different ?
  3. Zspoiler
    Zspoiler Veteran Member
    3,184
    247
    May 6, 2012
    Federal Way, Washington
    If you are going that route you could always put a Chevrolet LT-4 in it instead. Or a modified small block,big block .LS engine.Not a Mopar.
  4. Joey73RS
    Joey73RS Member
    30
    Oct 20, 2017
    There is no bellhousing on it.
  5. Joey73RS
    Joey73RS Member
    30
    Oct 20, 2017
    I have a 5.3 I will be dropping in it
  6. Joey73RS
    Joey73RS Member
    30
    Oct 20, 2017
    Wait there is a bell housing my bad. It's small so I didnt notice it loo
  7. badazz81z28
    16,371
    404
    Las Vegas, NV
    I would imagine not only is the bell-housing different (which can be swapped out), I bet a shiny nickel the inout shaft is a different length than GM application. Just guessing.
